oil cooler inlet pipe
Old Apr 12, 2015 | 09:49 AM
dannyg1121's Avatar
Why can't i find an inlet pipe for my max? It's like they don't exist. Is there another word for it? Or a part number?
Old Apr 12, 2015 | 03:14 PM
DennisMik's Avatar
What year car?
Engine oil?
Power steering oil?
Automatic transmission oil?
Old Apr 12, 2015 | 05:39 PM
Child_uv_KoRn's Avatar
Bad *** Newb
What year car?
Engine oil?
Power steering oil?
ENGINE OIL COOLER PIPE ON THE BOTTOM.
The one that rusts out if you don't paint it.
Old Apr 12, 2015 | 09:17 PM
Upperhand's Avatar
You can get it on courtesyparts.com. Their part number is 21302MS for the 5th gens. If you do that you might as well buy some other stuff to make shipping worthwhile, or check your local dealer. You won't find it on aftermarket sites. You might as well buy the oil cooler seal and do that too, unless you are already planning on doing them together.
Definitely throw some paint on it. I recommend VHT Engine Enamel. It is high temperature paint. I believe it is a ceramic based paint and claims chemical resistance when cured. I used it on my oil pan and it has held up nicely. You can likely find it at AutoZone for roughly $8, you won't even need a full can for two coats.
I’d just leave the factory paint on it but scuff it with green Scotch-Brite or light sandpaper, wipe with rubbing alcohol, tape the ends off, then paint soon after. As far as painting just hang it with wire and follow the directions on the can, except don't bake it. It will bake on the car. I would let it dry at least a few days, the longer the better in my opinion.
Old Apr 14, 2015 | 10:41 PM
DennisMik's Avatar
Only if your car was built with one.
Not all 5th gens have them.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Quickywd01
Sep 21, 2016 09:36 PM
05RLS2
Apr 14, 2016 11:49 AM
