3.0 running rich?
Old Apr 21, 2015 | 07:14 PM
AT978's Avatar
3.0 running rich?
Hey guys,
I've been noticing that for the past little while the car has been running rich. I'm not entirely sure how rich its running but its definitely very noticeable. Only mod I think that could affect it would be the intake. Also, I think that's why my car isn't performing to its full potential. I've several different OBDII dongles in hopes of adjusting the degree but none of them would connect to the car to my phone, or any of my devices to that matter. Don't have any codes besides the IACV which has nothing really to do with afr but I would really appreciate any sort of input. COME ON GUYS! Can't keep loosing to a camry!
Old Apr 21, 2015 | 07:50 PM
maxiiiboy's Avatar
If your car is indeed running rich, then there are two suspects: a) Your primary O2 sensors, and b) Your injectors. When is the last time you replaced your O2 sensors, if ever?
Old Apr 21, 2015 | 08:03 PM
AT978's Avatar
I was thinking o2 sensors as well, I have not replaced them. I have no idea if the previous owners did or not either. where are the primaries located?
Old Apr 21, 2015 | 08:12 PM
maxiiiboy's Avatar
https://maxima.org/forums/5th-genera...on-issues.html
Old Apr 21, 2015 | 08:24 PM
AT978's Avatar
Thanks man! now the question would be, if replacing the primaries didn't work and the injectors are fine, what else could be problematic?
Old Apr 22, 2015 | 05:04 AM
TDotMax's Avatar
My situation is a bit different, but it is simple and MAY solve your problem. My Greddy EU is street tuned and should not have any issues. However, over the winter I was throwing a code for running rich. All 3 of my O2's (fed spec) were new OEM so that was not the problem. My mechanic suggested my intake air temp sensor which I have tied up as I don't have a stock intake. So I got a new intake temp sensor from Nissan for $30CDN. Changed it and after driving enough for an ECU refresh, my SES light went off, gas mileage improved and no gas smell from my exhaust.
Old Apr 23, 2015 | 09:47 PM
AT978's Avatar
hmmmm that's interesting.. I may have to try that
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
AT978
Sep 6, 2015 10:31 PM
