ABS brake bleeding question.
Old May 24, 2015 | 04:12 PM
Donkeypunch's Avatar
Hi.
I bleed the front left line just to test out the bleeder and to clear
the probably oem fluid in the reservoir.
Drove it for about a week.
Now I'm doing a full system flush.
From what I'm reading I need to disconnect batt. and do it in this order.
Rear right
Front left
Rear left
Front right.
My problem is.... A ton of bubbles came out doing the front left this time.
Is this because I did not disconnect the batt. the first time.? Because I did this one out of order? The manual says do disconnect the batt. and do it in order for a reason, but is this the reason specifically or what do you guys think?
Old May 24, 2015 | 07:50 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Did you by chance run the reservoir a little low? It will suck in air before it's empty.
Old May 24, 2015 | 08:25 PM
idk, could be.
Can't recall if the res. was full when I bleed it for the final open/close.
Old May 25, 2015 | 02:00 PM
DennisMik's Avatar
Disconnecting the battery is just a safety precaution. Having it connected while bleeding the brakes did not cause the air bubbles.
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
