NEED HELP!!!! Not getting VOLTAGE
Old Jul 13, 2015 | 10:03 PM
Blake2000's Avatar
P105, P1320, P0306......I NEEED HELP!!!!!!!!!! I'm getting 12V on all ignition coils except, cylinder 6 hence, P0306 Anyone have this problem??? P0306 is causing all the other codes to pop up this only just suppose to be a misfire
Old Jul 13, 2015 | 10:46 PM
maxiiiboy's Avatar
Looks like your Crankshaft Position Sensor (Ref), or the associated connector/wiring, is suspect. You may also want to swap your coils, just in case it's a coil problem. For further details, see the FSM, page EC-584.
Old Jul 14, 2015 | 02:24 PM
DennisMik's Avatar
As I told Nestor last night, The red wire should have 12 volts on it all the time (when the ignition switch is on), the black wire is ground and the third wire (gray/red stripe) is the trigger from the ECM.
If you don't have 12 volts on the red wire, you have a wire harness problem. But before you tear apart the wire harness, try a jumper wire between the battery and the red wire.
AaronL
Nov 15, 2020 11:52 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
