Code p0300?
Old Aug 21, 2015 | 08:12 AM
Maxboy23's Avatar
Code p0300?
This code popped up after a week from putting on my 3 piece intake spacers I highly doubt it's a leak though I know most of the time this code I hear is from a bad spark plug or coil pack but mine were just replaced 7k miles ago with ngk plugs and coils I cleared the light then 70miles later the same code came on again and also a p0174 code bank 2 system to lean so is it a sensor? I replaced the bank 1 sensor 1 recently with the Oem bosche sensor I know that's a completely different bank could it be the man sensor? I just don't want to spend money on the wrong stuff
Old Aug 21, 2015 | 08:52 AM
foodmanry's Avatar
Da Roller Coaster!
I would suspect a leak since both codes popped up AFTER you installed the spacers.
Old Aug 21, 2015 | 10:28 AM
Maxboy23's Avatar
Yea just gotta find out where its coming from
Old Aug 21, 2015 | 11:02 AM
FanaticMadMax's Avatar
code P0300 usually says multiplies misfires, but since you don't have specific misfire code for what cylinder, so it's a vacuum leak, where you mention you put a three piece pipe, you have a intake leak, so you need to get carb cleaner and spray it on the piping while the engine is running and see where it sucking that's where your vacuum leak is at. it can be anywhere from a small leak to a gross leak
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
