1 of 2 climate control lights out--how to replace?
Old Oct 13, 2015 | 08:52 AM
TKHanson's Avatar
Folks:
Light on the left side of the AC/heater control on a 2000 SE is out. I'm sure it's not difficult to remove panels; however, I thought I'd ask for pointers--before I start pulling and hoping I don't break something in the effort.
Thx.
Old Oct 13, 2015 | 10:03 AM
TKHanson's Avatar
Ok so I pulled the stereo and AC/Heater controls as 2 units on one bracket. I think the LEDs that light the control panels are part of the circuit board; nothing I could see could be replaced from the outside (no bulbs, etc). Anyone know otherwise?
Old Oct 13, 2015 | 05:38 PM
foodmanry's Avatar
Da Roller Coaster!
I replaced them some time ago...I can't remember the exact procedure but it involved pulling the unit out and popping off the faceplate. Then you can pop off the buttons covering the lights. I think the LED bulbs behind the controls are only available from Nissan. I remember they were about $5 a piece.
Do a search for auto climate bulb replacement. Someone did a write up on here.
Old Oct 13, 2015 | 07:51 PM
Some of the bulbs are buried deep. You'll have to carefully open it by the little tiny screws and the clips. All bulbs are ultimately changeable.
Old Oct 14, 2015 | 09:40 AM
Derrick2k2SE's Avatar
You're almost there.
* remove the unit from the bracket by removing the 4 screws. 2 on each side. You may have to spread the brackets a little.
* Remove 4 very small silver screws on the back of the unit.
* The face will pull away revealing the circuit card.
* The bulbs mount through the circuit board. A 1/4 twist will remove them.
I actually have to do this again soon so I can do a write up if you need it.
Here's a pic of the bulbs.
Old Oct 14, 2015 | 02:55 PM
TKHanson's Avatar
LOL. Those look like Christmas Lights! Thanks for the details, everyone. Where would I order such bulbs? Might as well replace all of them on that unit, if they are not too expensive.
Old Oct 14, 2015 | 07:00 PM
Donkeypunch's Avatar
Ya take pictures and stuff.
Some of mine are not lighting up. Smacking them fixed most lights.
Old Oct 15, 2015 | 05:44 AM
rkspec's Avatar
I have to do it and saved the link that had a full write up with step by step pics
http://home.comcast.net/~kcmurphy72/i30/HVAC.pdf
BUT....the link is dead now. boooooooo
anyone have that .pdf?
Old Oct 15, 2015 | 07:11 AM
foodmanry's Avatar
Da Roller Coaster!
This may help. It gets you 90% there.
http://www.shiftice.com/Maxima_02-03...dio_repair.pdf
Old Oct 15, 2015 | 08:04 AM
TallTom's Avatar
I got mine from nissan and replaced all of them when I was in there.
They will be loose when twisting to remove but much tighter when putting in the new ones (which is a good thing).
Old Oct 15, 2015 | 08:26 AM
Prophecy99's Avatar
i replaced these w oem, and a year later same 2 on left went out
TKHanson
Nov 24, 2018 01:39 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
