Jerking around 2500rpms
Old Oct 13, 2015 | 02:42 PM
rkw2012's Avatar
Hello. 02 nissan maxima is having a jerking problem around the 2500 rpms and won't go past 70 mph. The car has 192,124 miles and has p0650 code and that's it. Changed out cam sensors and maf and still have the same problem. The only time it goes away is when I erase the codes and after 15 minutes it comes right back.
Old Oct 13, 2015 | 07:55 PM
fat_kid's Avatar
This might be related to: https://maxima.org/forums/5th-genera...-question.html
Old Oct 13, 2015 | 08:00 PM
fat_kid's Avatar
And learning how to search helps. ..
Here is the descriprion of P0650 from the FSM. It says this will cause the "fail safe" mode of operation, i.e., rpm limited to 3K. Only problem is that it requires a second code that woul cause the check engine light to come on. The P0327 knock sensor is not one of those codes.
this is from section EC, page 455 or 457, depending on which printing of the FSM you have.
If you don't have a copy of the FSM, you can download one from here:
http://boredmder.com/FSMs/Nissan/Maxima/
Jeffesernia11
Aug 23, 2015 06:09 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
