what tire size for 18 in wheels?
Old Nov 18, 2015 | 04:22 PM
Maxima50's Avatar
I picked up some factory 18 in wheels from a 05 Maxima that came with 215-55-18 tires. Looking to replace these with some that that will not rub. What tire sizes work with 18 in wheels on a stock height 03 Maxima?
Old Nov 18, 2015 | 09:34 PM
AT978's Avatar
A height aspect of 40 would keep the size closest to stock
Old Nov 18, 2015 | 09:40 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I would run 245/40/18. That's what I use on G35 coupe rims.
45 will barely rub in front on the fender liners.
Old Nov 19, 2015 | 06:55 AM
Maxima50's Avatar
I'm afraid the 40 series would ride too rough and leave a gap between fenders?
Old Nov 19, 2015 | 08:02 AM
Maxgig's Avatar
When I had my 03 SE I ran 245/45's on it and later used 235/45's with no problems at all.
Old Nov 19, 2015 | 08:31 AM
NmexMAX's Avatar
dot dot dot ...
245 40 18's looks fine on mine.
Summer set-up
Winter set-up
Old Jan 19, 2016 | 12:36 PM
losifanatic's Avatar
So do your 245/40/18s rub at all?
Old Jan 21, 2016 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
Not at all, when I had spacers one side would.
Old Jan 21, 2016 | 01:12 PM
IsaacFall's Avatar
I'm dropped 3 inches and have 225/45/18 and I don't rub at all, except for the right rear side, because I have 20mm spacers. On a side note, if you ever get spacers, get 15mm and not 20mm.
Old Jan 21, 2016 | 01:53 PM
NmexMAX's Avatar
dot dot dot ...
I also did this conversion (20-->15).
Also, one item to note is that I have 8.5" all around (all Z33 rears, +33 vs +30, 8" wide).
Old Jan 21, 2016 | 03:25 PM
IsaacFall's Avatar
Nice. I'm 8" all around with a 25mm offset in the rears. I did get my rear fenders rolled last summer, and that helped stopped the rubbing when it's just me in the car going over bumps. I still can't really have anybody riding in the back though. Do you think that stepping down to a 15mm would make enough of a difference without changing the look too much?
240tomax
Sep 13, 2015 03:28 PM
boomerbrian
Sep 2, 2015 03:46 PM
