Broken off Rotor Shield
Old Nov 28, 2015 | 06:44 AM
panabiker's Avatar
2002 Max with 201k miles. Recently, the shield behind a rear rotor was rusted and came off. Since installing a new one involves removal of the hub, I wonder if I can just drive the car without the shield (the FSM calls it baffle plate). What's the worst that can happen?
Old Nov 28, 2015 | 09:02 AM
DennisMik's Avatar
The shield is to keep stuff that is on the pavement from splashing onto the rotor. If the shield is missing, most of the time it won't matter.
But dirt with gritty stuff in it will wear the brake pad out sooner than normal and if you somehow got oil splashed on the rotor, you would loose braking power.
Old Nov 28, 2015 | 02:31 PM
Turbonut's Avatar
No problem, leave it off. There are new cars that are produced that don't even have a splash shield.
Old Nov 29, 2015 | 04:44 AM
panabiker's Avatar
Thanks. I will leave it as is. Pads are cheap. I'll avoid oily puddles if I see them.
Old Dec 1, 2015 | 03:36 PM
NmexMAX's Avatar
dot dot dot ...
The hub doesn’t need to be removed …. Just some elbow grease.
Anyone who has the FastBrakes rear BBK knows this and obviously the OEM unit cannot be used since the rotors are larger.
09maxshawn11
Mar 26, 2017 07:18 AM
furcioelbraveado
Dec 14, 2015 12:05 PM
keon3030
Nov 12, 2015 06:33 PM
keon3030
Nov 12, 2015 06:32 PM
