Maxmium fuel range
Old Dec 16, 2015 | 08:35 PM
Vistance's Avatar
Maxmium fuel range
What have you guys gotten for the maximum fuel range out of your Maximas? Asking because mine seemed to be exceptional this last tank, I had 330 on my trip and still showing 1/4 a tank and about 100 miles to empty but now I went to start it and it struggled to start - had to crank it over for about 6 full seconds before it started. Ran ok for a bit, then started to heavily drop RPM and then when I tried to rev it just went real low and died and the SEL came on. I'm suspecting it's just out of gas, though my gauge still shows 1/4 a tank and I have no fuel light on.
Typically I always filled up at 300 on my trip, just out of habit from my previous car but since I have another car now I was going to see at about what distance my fuel light came on. I never ran it low enough to see it when I drove it regularly, but what kind of distance could you guys get at best out of yours? Is there a big difference between the 6-speed and the auto?
Old Dec 17, 2015 | 08:18 AM
NmexMAX's Avatar
dot dot dot ...
Is this another what's your MPG type thread?
I get anywhere from 360 - 400, of course, not the maximum range since I don't like to walk to gas stations with a fuel container.
4AT here.
Old Dec 17, 2015 | 08:45 AM
foodmanry's Avatar
Da Roller Coaster!
Just drive till you run out of fuel and see how many miles or what happens.
Old Dec 17, 2015 | 09:04 AM
Fakie J Farkerton's Avatar
Old Dec 17, 2015 | 09:31 AM
Vistance's Avatar
I really only care because I'm trying to figure out if it's likely that I ran out of gas, or if there's something mechanically wrong with the car. I already know my MPG, it's about 21-21.5 MPG and that's driving it mostly highway, but plenty of good acceleration mixed in with mild amounts of traffic. I track all my fill ups on Fuelly as it's pretty nice for keeping track of every fill up on your car.
So at 350 miles, maybe I did run out or I'm to the crappy parts of gas in the tank. I've never even gotten the fuel light to come on as I usually fill up at 1/4 a tank but thought I'd push it this time. Shows me what I get for doing that...
Old Dec 17, 2015 | 11:08 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Check the code. It's pointless to speculate. And if you're really bored, then spend 2 mins and look in the gas tank.
Crank/cam sensor is likely to be the culprit.
Old Dec 17, 2015 | 12:08 PM
Vistance's Avatar
I have a second car so it's not as huge a deal as it would otherwise be. I just poured some gas we had saved up for our lawn equipment and it seemed to run ok. I put a code reader on it and it looks like the SEL only come on when it dies so just part of the normal startup procedure where it lights up I think. I'll recheck again tomorrow and make sure it doesn't die again and probably just have a buddy follow me to a gas station. Guess I shouldn't have been so trusting of the distance to empty or my fuel gauge, though I was never aware of it being so far off. Even now it shows over 1/4 a tank, but by my estimate it probably is about empty. I'm not going to chance it anymore, back to my every 300 miles fill up interval.
Old Dec 17, 2015 | 01:33 PM
Bad *** Newb
If it is empty, then the fuel sending unit is bad. It's an easy replacement, but good luck getting just the sending unit.
Old Dec 17, 2015 | 03:05 PM
cornholio's Avatar
i can get over 400 on a fresh tank driving highway
3.0 at
ymmv
Old Dec 17, 2015 | 03:50 PM
NmexMAX's Avatar
dot dot dot ...
3.0 at
ymmv
And here we go ...
Old Dec 17, 2015 | 04:25 PM
foodmanry's Avatar
Da Roller Coaster!
3.0 at
ymmv
Oh yeah...well I set my cruise control to 30MPH and can driver 4ever!!!!!!!
Meh..who the fck cares.
Old Dec 17, 2015 | 05:14 PM
cornholio's Avatar
op cares or he wouldnt have asked the question
Old Dec 17, 2015 | 05:17 PM
cornholio's Avatar
4AT here.
And here we go ...
Old Dec 17, 2015 | 06:59 PM
maxinout93's Avatar
of course the 3.0 is gonna get better gas mileage, its the 3.5 that gets less miles per fillup.
Old Dec 17, 2015 | 07:20 PM
Bad *** Newb
All hwy at 400 miles is almost 27 mpg when the light comes on. A 3.5 can EASILY do that if you're not speeding and don't have ****ty grades (80 mph limits excluded).
Old Dec 17, 2015 | 07:37 PM
maxinout93's Avatar
sounds kool im gonna have to give it a try once i get mine ready for the long trips. I use to get like 380-400 in my 3rd gen.
Old Dec 18, 2015 | 02:39 PM
Vistance's Avatar
Sorry fellas, wasn't trying to start a "here's my best possible tank with A/C off, cruise control at 50 mph" or anything, I just don't know anyone else with a Maxima to compare how many miles they could go for a fillup. I had a Buick before that at best could do 320-330 miles in a tank, but it would be bone dry at that point and it averaged about 18 mpg. I figured since I got about 21 mpg on the Maxima and it has a gas tank 2 gallons bigger I could get maybe 380 miles out of it, but I think 350 looks to be about it (and I don't drive conservatively nor do anything to try and get better mileage).
Old Dec 18, 2015 | 07:08 PM
Donkeypunch's Avatar
From fill up, to the gas light just turning on
it's about 300 miles for me.
I get up to work at 3 and drive back with the a/c on. That's about all I use the max for, work.
Rarely I drive like 100mph when I'm running late, but that doesn't seem to effect much.
2000 automatic. Engine and trans are maintained perfectly. So there you go.
Oh. On a camping trip I got like 430 miles but it was 100% freeway 65mph
so your mileage can fvcking very allot.
The bmw on the other hand I fill up every 150 miles.
Old Dec 18, 2015 | 07:20 PM
george__'s Avatar
Ontario
With the stock 6 speed HLSD transmission
During the winter gas stations change the formulation of the gas so mileage drops to 300 - 400 km depending on how gas heavy I am.
During the other seasons 450 km is usually the average.
Highway driving the car hits 500 - 600 km no problem
When I had the AT Maxima with bolt ons I had awful mileage.. 300 KM on a good day
This is all before the needle hits 2 lines, I never go until the fuel light comes up
Old Dec 19, 2015 | 07:29 AM
Bad *** Newb
Light comes on at 3 gallons left if anyone was wondering.
Old Dec 19, 2015 | 11:12 AM
Vistance's Avatar
Went to get gas today, and it took 17.2 gallons. So accounting for the fact I poured a bunch in from our powertools gas can I'd say it ran bone dry. No fuel light on even on the drive up. When I filled it up, the needle was actually sitting on top of the F, so it looks like it's about an 1/8th of a tank off. Damn gas gauges, besides my Mustang I haven't been able to trust any of them and that one is only because it's a 2013. Lucky for me the Maxima made it home and then ran dry though, could've been much more annoying to deal with. No more high mileage runs for me! I don't remember if I said already but that makes 350 miles my maximum range and I actually got just under 21 mpg on this fillup.
Old Dec 19, 2015 | 04:18 PM
cornholio's Avatar
reminds me of my 3rd gen, the gauge stopped working so i'd have to reset the trip counter and remember to refill around 300 miles. not once did i run out but it was annoying not knowing what was in there.
Old Dec 20, 2015 | 11:17 AM
Vistance's Avatar
My old Buick was the same way, gas gauge was accurate until 1/4 a tank then it rapidly went to empty so I couldn't trust it. At this point I trust using trips to figure out when to get gas so much that I barely even look at the fuel gauge, although in the Mustang I can at least trust it. It also alerts me exact mileage until empty each time I start it if low, and so far has been pretty accurate.
I wonder what goes bad in cars as they age that makes their fuel gauges become inaccurate?
Old Dec 20, 2015 | 02:53 PM
Bad *** Newb
If you know the mileage on the junkyard cars, then one with lower miles would be a safe bet.
Sometimes they last forever...sometimes not. Same general design in a lot if not most cars.
Kinda sounds like your is getting stuck, since it works fine except when it runs low.
Old Dec 21, 2015 | 04:41 AM
Prophecy99's Avatar
actual tank is 17.5 gallons, so yea u were bone dry !
and once the light is on 3 gal till empty is good to know ,
my light works fine, if I ride around a day with the light on, and the fuel needle is like scary and you know u are pushing it and pushing it .. the most my fill up will be is around 16.6~16.8 gallons, always the case, if I fill up around when the fuel light first comes on its around 15.5~15.75 gallons
Old Dec 21, 2015 | 05:38 AM
Bad *** Newb
Interesting. All of mine when the light comes on only fit 15 gal on the nose.
Old Dec 21, 2015 | 08:10 PM
Mateen995's Avatar
I used to average about 400km till it dipped just below the 3/4 empty mark. Fuel mileage was whatever on my old 4AT 3.5
Old Dec 22, 2015 | 08:14 AM
Prophecy99's Avatar
i rarely do a full full up under 15.5 gallons, if i ride a day or two with light on around town and "push" it then its usually way closer to 16.5 gals,
and i just checked the manual and it says our tank is 18.5 gals capacity, so your theory with 3 gals left when light is on seems legit too.
Old Dec 22, 2015 | 06:03 PM
I used to get better mileage with the maf messed it.
Old Dec 22, 2015 | 07:59 PM
maxinout93's Avatar
yah all the maximas ive had have 18.5 gallon tanks.
Mahmuth
Dec 11, 2015 06:59 AM
gman214
Oct 20, 2015 06:47 PM
blissfulfantasy
Oct 18, 2015 08:33 PM
mclasser
Oct 13, 2015 02:50 AM
blissfulfantasy
Oct 6, 2015 05:26 PM
