Bank 1 sensor 1 location on obx headers?
Bank 1 sensor 1 is the upstream right second upstream on the back header right? Is it the light blue or dark blue clip
If its cali spec I think B1S1 is on header closest to the firewall right before the pre-cat. should be black wire.
Yea i see it only thing that sucks is im going to have to splice the sensor because its to short
[QUOTE="Maxboy23;9112857"]Yea i see it only thing that sucks is im going to have to splice the sensor because its to short[/
Not sure about obx but with cattman you just needed to unclip the sensor harness from the metal piece that holds the connection in place and it was enough slack to reach the bung. You could probably carefully open the wiring harness and pull some extra out to make it reach. As only a last resort would I try to extend the wires. If you absolutely have to extend the harness side don't try to extend the sensor side it's next to impossible to do. The wires used on the sensor side are aluminum I believe and are very hard to solder correctly. |
Thats a really good idea never thought of that
Originally Posted by Maxboy23
(Post 9112877)
https://cimg7.ibsrv.net/gimg/maxima....232b3c255.jpeg back up |
(Post 9112877)
Well that explains why my bank 1 sensor 1 light was coming on the previous owner put it in the wrong hole! Its mounted all the way at the bottom near bank 1 sensor 2 hahaha
Anybody know what size bung weld im gonna need to cover the hole
Wait im sorry guys i meant the one for back header
(Post 9113925)
Oh ok thats good to know i had to splice the second upstream the one in the front fit fine the one in the back was to short
Originally Posted by sebastian2041
(Post 9113929)
I covered my bung with an 02 replacement plug bolt thingy from napa i have an extra one! Btw the location of the o2 sensors shouldnt matter as long as the primaries are plugged in your car should run fine right now i have 2nd sensor bank 2 completely of my car and it runs fine just the CEL but pnce i get the o2 simulator i should be fine.
So is there a way to connect the second upstream on back header without splicing the sensor to extend it
(Post 9114055)
Would you be able to get a picture for me?
(Post 9114068)
Yea lol the other guy confused me because i just noticed he had a picture of the front upstream
(Post 9114082)
Yea thats the one
Ok so here's all I did. See the metal post in first picture? That's what sensor is mounted on.
https://www.dropbox.com/s/kdjiymbgu7...28.35.jpg?dl=0 Remove it from the post once I did that I had plenty of slack. https://www.dropbox.com/s/gka3jt3rlq...27.14.jpg?dl=0 Now it just lives there. If you need slack just peel back harness tape pull slack out. Doesn't get any easier. |
Oh now i see thanks
No problem did it work for you?
Yes mow all i have to do now is fix the stupid p0705 problem transmission range sensor what eever that is -______- i replaced the neutral safety switch the light still comes on the guy at autozone sayed its not saying the sensor is the problem its saying there is low voltage so im guessing maybe a wire on the harness is bad
(Post 9114107)
© 2024 MH Sub I, LLC dba Internet Brands
