03 Maxima not staying started
Alright, so this is a long story.. I had to change the clutch and the crankcase main seal on my 03 Maxima 3.5L V6 6 speed manual. That all went fine. We slammed the ***** back together and go to start it, and it only stays started when the throttle is floored at only about 300 rpm. Checked spark plugs, grounds, pinched fuel lines, blown fuses, MAF, and fuel rail is still getting fuel at a good pressure. We ran codes but we only got one that was P0462, which is a fuel level sensor A low circuit input, but we figure that that only came up because my cluster is ****ed and the fuel guage always reads full and speedo is ****ed. I'm fresh out of ideas and just need help.
Originally Posted by Wonder_balls
(Post 9121566)
^^^^ +1
(Post 9121586)
^^^^ +1
Originally Posted by Mattx
(Post 9121569)
Did you put the flywheel back on in the correct position?
(Post 9121691)
I'm pretty sure I did man.
Did you Relearn the idle, and Check your ground wires ?
Originally Posted by tech2000
(Post 9121752)
If this is an 03 then you should have a electronic throttle body on your motor, Mabye there is an loose wire from the throttle to the pedal or the motor in the TB died. If you have access to a diagnostic scanner, check out the throttle percentage and see if the % goes up as you hold the gas( car doesn't have to be running, just acc2)
Originally Posted by MadMax SE
(Post 9121783)
(Post 9121781)
Checked all of the grounds. What do you mean by relearning the idle?
(Post 9121789)
Check this out hope it helps https://maxima.org/forums/5th-genera...a-02-03-a.html
(Post 9121810)
Reset the ECU, car still didn't start. Although the air around us smells really gassy so I'm thinking it might b3 an air problem
(Post 9121844)
I think you're trying to look for a problem when you already know what the real one is. Did you recheck the flywheel yet? Cause the ecu reset and various relearns won't stop the car from running. It might not run right but usually it would still run. On top of that you weren't really sure which hole was the dowel pin hole to begin with were you?
(Post 9121897)
No I wasn't. When we put the flywheel on we had to wiggle it around so that all the holes properlly lined up, which is why I think we put it on the right way. I mean, I wish I could check it without spending a full night's work and tearing apart half the car.
(Post 9121566)
(Post 9122512)
Thanks to everyone who helped out! I faced my fears and took everything off. Flywheel was on wrong and after we put it together it started good. Did a few celebratory burnouts as well! Thanks again fellas!
Did your gauges get straightened out? Mine have gone wacky too, only it's all of them. |
Originally Posted by Blassmasta
(Post 9122534)
I'm having deja-vu right about now brother. Going through the same sh#t myself. My car runs and is driveable so I'm pretty sure I have the flywheel out of position by one hole on the crank flange. I will be making time to fix this soon but the question I really want the answer to ...
(Post 9122551)
Sadly no. At least not yet. We snapped the bolt for the main ground to the trans last night and have to go buy one somewhere. But I don't think that's the problem. I'm pretty sure it's just the whole cluster is screwed. Because even the odo only clicks a km about once every 3 km travelled. And after changing all this crap, I don't have the money right now to replace it.
They all work it's just that their start / resting points have been altered somehow. My odometer is working as it should. Have you done the self-diagnostic on the cluster? |
© 2024 MH Sub I, LLC dba Internet Brands
