I need clutch pedal assembly. Where to get one?
Old Aug 19, 2016 | 03:44 PM
mahanddeem's Avatar
Hello,
Nissan Maxima 2002 Manual transmission.
I narrowed down my clutch noises and popping to the clutch pedal itself(and its mechanism).
Part no. is 46540-2Y900
No longer produced by Nissan
I really don't want to get a beat up used one from a junkyard.
What are my options?
Would a part from G35 or 350Z or a newer maxima would work?
Aftermarket one?
Please help me.
Old Aug 19, 2016 | 05:44 PM
PowerTotheMax's Avatar
http://www.nissanpartsdeal.com/parts...540-2y900.html
Don't know if it's related to your issue but I also had popping on my clutch pedal and I could see the spring shift when I was underneath. I greased it and the noise and pop feeling went away. Just use something that doesn't smell bad.
Old Aug 19, 2016 | 10:27 PM
mahanddeem's Avatar
The clutch return spring is exactly where one of the plastic/rubber "bushings" is worn out. I'll try to put some spray grease on it.
Old Aug 19, 2016 | 10:28 PM
mahanddeem's Avatar
I also contacted nissanpartsdeal by phone.
They said they can't sell me the assembly because it's discontinued by Nissan.
Old Aug 20, 2016 | 12:56 PM
Derrick2k2SE's Avatar
Is it one of the bushings on the side or the horse shoe shaped bushing in the center?
Old Aug 21, 2016 | 09:14 PM
mahanddeem's Avatar
The center one is busted.
Old Aug 22, 2016 | 06:02 AM
A couple of ideas.
That bushing is U shaped so it clips in place without too much effort.
I'd look around in some U-pull it style salvage yards where you can just pull the clip. That same clip may have been used on other manual Nissans so that opens up your search. I just looked under the dash of my 220,000 mile 02 and that bushing is perfect so they're not all worn out.
Another option would be to make a clip out of some water pipe with the same inner diameter as the spring. You can also Google "nylon bushing" or "plastic bushing" and find pieces you could modify. The diameter of the spring is .117" or 4.5mm so a piece with that inner diameter would work. I couldn't measure the outer diameter but you can grind it to fit.
A quick fix would be to wrap some duct tape around the spring to build it up to the size of the fork it clips into. It wont last forever but it'll quiet it up for a while.
There are a lot of cheap options to fix it in the car rather than replace the entire assembly.
Old Aug 27, 2016 | 06:04 PM
mahanddeem's Avatar
A couple of ideas.
Thanks man. I was thinking the same, to pull the entire thing out and dive into it to see what to do. Problem is being my daily driver would make it difficult just to pull it cluelessly and end up with a f'ed pedal.
Anyone has an idea of what new part from another model max would bolt on for the 2002?
Old Aug 27, 2016 | 09:37 PM
Mattx's Avatar
I'm just guessing I don't have a manual trans but I'd say any nissan with a six speed trans most stuff would be interchangeable. One of the veteran manual trans guys will correct me if I'm wrong but that's my educated guess.
Old Aug 28, 2016 | 05:39 AM
You wouldn't have to pull the assembly out for any of this if it's the bushing on the return spring. At most you would remove the return spring but that might not even be necessary. The spring will come out if you force one side out with some pliers. Just remember how it went in because it will install wrong if you let it.
valerit1
May 19, 2016 04:13 PM
maxima297
Mar 11, 2016 06:27 AM
Maxima 97 SE
Feb 29, 2016 09:04 PM
RussMaxManiac
Sep 6, 2000 06:13 AM
