Pre Cat Gaskets for 5.5 ?
Old Oct 5, 2016 | 04:55 PM
SquidBeak's Avatar
Can anyone confirm exactly what gaskets I'll need when replacing my pre-cats with gutted cats?
All of the online parts sites are very unclear about this.
As far as I can tell, it seems that I will need:
1. 20691-8J100 for the top of the rear (firewall) pre cat
1. 20691-30P00 for the bottom of the rear pre cat
1. 20691-51E01 for the bottom of the front pre cat
I don't think there is a gasket for the top of the front cat with the large opening.
Can someone please set me straight on this? I want to make sure I have the correct parts before I start this nightmare.
Old Oct 6, 2016 | 04:34 AM
Prophecy99's Avatar
wish i could help, just had a shop R/R mine, i think u r on right track, i am thinking there was some info out there on gaskets needed in a thread or two lemme look around
Old Oct 6, 2016 | 04:42 AM
Prophecy99's Avatar
https://maxima.org/forums/5th-genera...g-cat-bug.html
https://maxima.org/forums/5th-genera...while-car.html
https://maxima.org/forums/5th-genera...-pre-cats.html
Old Oct 6, 2016 | 04:08 PM
MaximaNoob1's Avatar
I see that the front is much easier than the rear, as in terms of the honeycomb strength. So would be alright to gut the front one, but leave the back? I know someone will say do both, but if the rear is so much stronger, it shouldn't break apart, right?
Old Oct 6, 2016 | 06:17 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Nope and nope. They're the same strength, but the front one pops loose and rattles around. A few members have posted that their rears were in pieces (it usually is the front, first, though). Half-assing **** never fixes anything.
Old Oct 6, 2016 | 06:18 PM
Nope and nope.
Old Oct 6, 2016 | 06:28 PM
Bad *** Newb
Might as well buy the dirt cheap altima headers and have the Y pipe modded to work.
Old Oct 6, 2016 | 09:53 PM
Max139617's Avatar
If you would like to make your life easier I have a front pre cat that I could sell you which you can gut off the car. Shoot me a pm if interested
Old Oct 7, 2016 | 04:31 AM
Prophecy99's Avatar
search maximanoob there was a thread on only doing one or the other
Old Oct 7, 2016 | 06:28 AM
Ok, my bad.
Old Oct 7, 2016 | 06:29 AM
The front isn't the issue for me, it's the rear one.
Old Oct 7, 2016 | 06:41 AM
****, I also didn't know Altima headers didn't fit in Maxima's. F*ck my car lol.
Old Oct 7, 2016 | 10:11 AM
Reallyslowrio's Avatar
4th gen headers fit. You just have to plug the egr port and the extra O2 sensor hole.
Old Oct 7, 2016 | 10:34 AM
No flange modification needed? Cool, I'll look into a set of those on eBay.
Old Oct 7, 2016 | 11:52 AM
I've been researching this for the past few months, just haven't pulled the trigger yet.
Apparently the blocks are the same from 95-08, so any manifold will bolt up. The Y-pipe is the issue with the Altima headers/Y and the 04-08 headers/Y.
I've read that people have used the 4th gen headers/Y on the 5th gen no problem, and also that people have used the 5th gen headers/Y on the 5.5 gen no problem.
Old Oct 7, 2016 | 12:42 PM
Hmmm, hopefully someone else who has done this can chime in.
Old Oct 7, 2016 | 02:46 PM
Bad *** Newb
That's correct. 4th gen is nearly the same as 5th. The catback will even work, technically. It's just too short.
Old Oct 7, 2016 | 03:43 PM
maximatech12's Avatar
Do ya just install spacers afterwards for the HO2S?
This keeps the output mV within the correct range?
do the de-foulers have valves in them?
Old Nov 16, 2016 | 07:35 PM
SquidBeak's Avatar
Just looking over this thread I started.
How did it go from precat gaskets to 4th gen Altima headers?
Old Mar 24, 2017 | 02:10 PM
SquidBeak's Avatar
Could anyone answer the question in my original post?
Old Mar 28, 2017 | 05:21 AM
Prophecy99's Avatar
why dont u just buy every gasket you think you may need, then return what you dont need?
Old Mar 28, 2017 | 05:33 AM
Prophecy99's Avatar
i have some ring gaskets laying around from this project still from the shop that didnt use or reuse / everything
Old Mar 28, 2017 | 12:55 PM
SquidBeak's Avatar
I have the 3 gaskets that the parts catalog shows.
I think there should be a 4th gasket of some sort, that should mount on the large opening of the front pre-cat. I really want to be sure I have everything before I start this.
Can you post a pic of the gaskets you have?
Old Mar 29, 2017 | 10:10 AM
Prophecy99's Avatar
sure once I get home, i may have stashed them somewhere, no promises but i can try!
Old Apr 15, 2017 | 01:06 AM
SquidBeak's Avatar
If anyone is interested, the 3 gaskets I listed in the OP are all that is needed.
Donkeypunch
Aug 21, 2016 08:20 PM
pjgreek
Aug 17, 2016 08:23 PM
BobMax
Aug 11, 2016 04:24 PM
GGrant
Aug 9, 2016 04:49 PM
BobMax
Jul 18, 2016 12:15 PM
