Floor Jack Point.
Old Jan 25, 2017 | 03:17 PM
Noela's Avatar
Floor Jack Point.
Hello folks,
I know this has been asked several times, so pardon me -- most of the old posts have lost their picture links.
I looked at the factory manual and have seen the lift points indicated there (see figure 1).
I have spent sometime this evening trying to locate it on my vehicle. I think I have spotted it at the front end - can you please confirm if this is the right lift point (see Figure 2).
If not, can I lift each side using this point (See Figure 3), place the jack stands and then move to the other side?
thanks - MN
Attached Thumbnails Floor Jack Point.-jackpoint_factory.jpg   Floor Jack Point.-jackpoint_fm.jpg   Floor Jack Point.-jackpoint_alternate.jpg
Old Jan 26, 2017 | 06:26 AM
SubwayVQ's Avatar
The second pic with the bump sticking down is the correct spot.
Old Jan 26, 2017 | 08:12 AM
jackman's Avatar
All the times I've crawled under mine so far, I don't remember seeing a bump like that. Where is it? I always raise the front with a floor jack at one of the LCR attachment points, then add a safety stand at the sill.
Old Jan 26, 2017 | 08:55 AM
SubwayVQ's Avatar
Right underneath the radiator. Follow the crossmember bar that runs directly under the engine, you can't miss it.
Old Jan 26, 2017 | 04:36 PM
jackman's Avatar
Don't a lot of these cars have a radiator support that's held on with nothing but rust? I'm not sure that was ever a good place to jack, let alone now that these are 17 years old.
Old Jan 27, 2017 | 01:14 PM
embracedsword's Avatar
I've lurked the forums a lot and there has been multiple surprises when the lower radiator support gave out because they used the jackpoint on the manual. I believe if you do some searching there are some pictures on another user's alternate jacking points that are safe to use.
Old Jan 27, 2017 | 03:55 PM
YaSasha's Avatar
This is absolutely true. If you have a good jack you can reach behind the little mound pictured and follow the bar a good while back to reduce tension on the lower rad support.
Alternatively go for the pinch welds.
