My Son was given a 2001 maxima
My Son was given a 2001 maxima 124k miles looks, and runs well.
the service engine soon light is on, car runs fine. His uncle says the codes were scanned a while back he thinks it was random misfire
@124K miles I'm certain the plugs have never been done, and they are on the short list with (coil)s and the ignition condensor
I've ordered a ELM327 OBD2 bluetooth reader from amazon wondering If I'm able to retreive codes without a scanner? (old timer with Z32 VG30DE experiecne) I've used the SEARCH feature
So yea, can I read codes without a code reader?
Thank's in advance Guys
Buy yourself a reader, such as https://www.amazon.com/Vehicle-Reade...db+code+reader - it's only a few dollars.
With our cars, you'll need it repeatedly; it will pay for itself soon.
Buddy says P01320 is the only code
I'm suprised there was no other codes, I was half expecting a code for a specific cylinder misfire
As mentioned above the car seems to perform well, no ping no shakes nothing,
This things got more ***** than I want Him to have !
a week ago we were looking at 4CYL manual trans Ferd rangers
I'm waiting on my bluetooth OBD2 dongles can someone please clue me in on How to turn off the SES light This is a 2001 model
If the light comes back on, there is indeed something wrong with your ignition subsystem. The EC section of the FSM lists the possible causes on page EC-584:
- Harness or connectors (the ignition primary circuit is open or shorted),
- Power transistor unit built into ignition coil,
- Condenser,
- Crankshaft position sensor (REF),
- Crankshaft position sensor (REF) circuit.
Hey Guys thanks for the input, I appreciate it very much Thinking about untaping that igntion condenser and having a peek
maxiiiboy read about the mounts and IAC issues regarding ECU BBQ's Good to know Thanks for taking Time and making those links in Your Sig Good one on ya mate
I do like the way Torque lets you setup multiple dash boards with custom gauges.
I'd oredered the condenser fron the local dealer and it arrived this morning, we drove the maxima to the dealer and on the way back it threw the SES light @ 24 miles since resetting the ECU
the car stuttered and the light came on
We pulled over and plugged in the new condenser drove another 5 miles with the SES light on
waiting on a scanner an autel AL519 6 Hibatchi coils, and 6 ngk laser iridium spark plugs
As mentioned at the beginning of this thread, the car starts instantly and it idles, and accelerates well.
The coils, and plugs are do to arrive in the next day or so. I've read all the threads here, after searching p1320
Got to admit I'm feeling a bit nervous about getting this car right for my son
I'm assuming a bad CPS would cause hard starting. and/or even spark knock
issues, that said we are into it 6 hitachi coils 6 NGK IX plugs and a condenser
Boy I'd sure like to get this thing smogged so the kid can drive it
If you can't, I'll come take it off your hands. Lol.
Good luck. My coils always failed pretty quickly on me. I would get intermittent misfires for a week at most before the coil failed 75%+. I scored a full set of 2001 coils for $35 from the local junkyard so I always carry a spare in the trunk. Flathead to pop the plugs and see which one is dead. 10mm socket to pull it. Had 3 die on me in 170k miles. 1 at 90k and the other 2 somewhere around 130-150k
Even taught the wife how to diagnose it when the last one died. She limped it 40 miles home with a totally failed coil :'O
