MAF replacement
Old Feb 9, 2017 | 10:31 PM
Michaelrob's Avatar
MAF replacement
Hello all!
I'm wanting to replace the MAF sensor on my daughter's 2000 Maxima. Can I just replace the sensor or do I need to buy the whole housing with sensor attached? Can someone also throw me the genuine part number for this?
Thanks guys!
Old Feb 10, 2017 | 09:01 AM
SubwayVQ's Avatar
Originally Posted by Michaelrob
Hello all!
Thanks guys!
You can just replace the sensor itself, no need for another housing unless it's damaged.
Just go on RockAuto and find a Hitachi brand one. That is an OEM MAF sensor and will work great. Don't put any other brand on.
Old Feb 10, 2017 | 09:52 AM
Michaelrob's Avatar
Thanks man!
Old Feb 10, 2017 | 11:20 AM
Michaelrob's Avatar
Dang, the only Hitatchi one they have is with the housing too. They have Delphi, Spectra, Airtex.
Old Feb 10, 2017 | 12:08 PM
jackman's Avatar
Just to cover all the bases, you did try cleaning it, right? My 2000 was stumbling and bogging like crazy, getting worse by the day, almost undriveable. A shot of MAF cleaner took care of it.
Old Feb 10, 2017 | 09:32 PM
Michaelrob's Avatar
Yes sir, just got done cleaning the old one. Still running rough but it did seem to help the idle somewhat!
When I floor the accelerator, it bogs down but when I let off the gas a little bit, I starts pulling and acting normal again. I'm kinda stumped now. I've heard of MAF sensors going bad and cleaning didn't help.
Old Feb 11, 2017 | 12:14 PM
jackman's Avatar
Yep, I've read about them failing on these cars, and it seems to be a frequent cause of trouble. I don't think there's any way to diagnose a bad MAF other than replacement, so you'll probably have to bite the bullet. The OEM Hitachi part is $122 at Rock, and you're right, it only comes with the housing. I don't think that's an outrageous price though.
Old Feb 11, 2017 | 08:41 PM
Michaelrob's Avatar
Thanks, yeah I guess I'll just have to try a new one!
Old Feb 15, 2017 | 03:34 PM
Michaelrob's Avatar
I bought a MAF from salvage yard. That MAF has 5 prongs whereas the MAF on my daughter's car only has 4. But I saw that the cars wiring plug has receptacles for a 5 prong plug. So I installed it, started the car and the car will immediately sputter and stall until it finally dies. BUT I can rev the motor and the RPM's will go up as far as I throttle. Put the original MAF back on the car. Car does like before, it will idle fine at 1000 RPM's but when I hit the throttle, It will only go up to about 3000RPM's. If I floor it, it bogs down bad. I'm not sure what to do at this point
Old Feb 15, 2017 | 05:10 PM
Michaelrob's Avatar
You guys think I should do a relearn procedure with the newer MAF installed?
Old Feb 16, 2017 | 08:37 AM
jackman's Avatar
Yes, but it won't solve the problem is there's a mismatch between the car and the MAF. Maybe someone else here knows whether the 5-pin and 4-pin versions are interchangeable.
Old Feb 24, 2017 | 09:49 PM
District's Avatar
Hey, could you describe some of the symptoms of the car with the bad MAF?
Old Feb 25, 2017 | 10:11 AM
1madmaxima03's Avatar
It would be good if everyone remembered to clean the throttle body with carb cleaner and a brush, wiping the butterfly with a micro fiber cloth at the same of MAS cleaning. You will see a lot of carbon buildup, just be prudent and use common sense when addressing this process.
Old Feb 25, 2017 | 12:47 PM
maximatech12's Avatar
Does the MAF code flash when it happens? If not it's hard to say it's the MAF could be a fuel pump or regulator.
