So, I have a serious PROBLEM! 😔
Old Mar 25, 2017 | 05:57 AM
CityBoyMase's Avatar
So, I have a PROBLEM! My father in law and I replaced my clutch, throw out bearing, and flywheel. On my 00' Nissan Maxima. I drove it to work for 2 days and on the 2nd day it grinded while down shifting from 4th to 3rd, to get off on and exit to a complete stop. [stop sign] From then on it would not let me go in to 1st gear or 2nd gear. Only 3rd, 4th, 5th and Reverse works. I've tried bleeding the master cylinder and slave cylinder. Still I can't seem to get it into gear. Does anyone have an idea on what had happen?
Old Mar 25, 2017 | 01:21 PM
Derrick2k2SE's Avatar
Doesn't sound like a clutch issue or it wouldn't go into any gear. The clutch system doesn't care what gear you're going into. If the car is stopped and running you need the clutch to go into any gear.
I would check the shifter linkages where they connect to the tranny.
I would also check the fluid to make sure he replaced what was lost when pulling the tranny.
Was it a stock clutch?
How does the stick feel?
Old Mar 26, 2017 | 08:44 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Werd. No fluid means nonworking synchros.
And it's really weird how it goes from shifting fine to nothing. My Z32 ran low. Parked it and 30 mins later it refused to go into first. Drained and filled, then it was good as new.
Old Mar 26, 2017 | 01:07 PM
Les7311's Avatar
Is the drive axle all the ways seated into the tranny case?
