Trouble codes can anyone help
Old Mar 27, 2017 | 11:42 AM
09maxshawn11's Avatar
I have my 2002 nissan maxima 3.5 se and today I finally pulled it out the garage and started driving it I have 4 codes that's popped up but actually it's 2 that repeat each other 1 code is p0303 and the other is p1800 but both repeat can anyone help me out with these codes please
Old Mar 28, 2017 | 08:59 AM
DennisMik's Avatar
P0303 is a mis-fire on cylinder 3. The majority of the times it is a bad ignition coil.
P1800 is the VIAS Control Solenoid Valve. This isn't harmful to the car, but it causes a tiny bit of power loss at full throttle. The solenoid is easy to get to, it is is bolted onto the intake manifold towards the passenger side. It is Nissan part # 14955-8J10A. Very expensive, list price $212. You can get it on-line for around $150 plus shipping. I don't know if you can get this at a local auto parts store, it might be a dealer only part.
Old Apr 3, 2017 | 06:34 AM
ok thanks now I have replaced my coils all six with some coils from ebay possibly a bad idea but the car doesn't skip at all anymore seems to be running well but when I checked the code reader still gave me that cylinder 3 misfire code is there something im missing like a computer reset or something?
Old Apr 4, 2017 | 07:25 AM
Derrick2k2SE's Avatar
Did you clear the code after replacing the coils?
The VIAS solenoid can be found in your local U-pull it yard. Altimas, and I think even Quest vans, from the same time have the same piece.
I may even have one floating around here. If you want it send me a PM. We'll work something out.
Old Apr 4, 2017 | 07:29 AM
Robert Baker's Avatar
About the VIAS. I did a little research on the VIAS thing and it turns out the rod inside is poorly designed and just stops doing it job and falls off. I used a tiny bit of jb weld to fix it. Just a thought as ALL VIAS will eventually do this from what I read.
Old Apr 5, 2017 | 06:52 AM
This is mostly a problem with the 3.0 liter cars.
The VIAS, and the entire intake, on the 3.5 liter cars is different.
Old Apr 5, 2017 | 07:01 AM
I ordered the part the sane day i found out i needed it wasnt too expensive its in transit now but thanks for the offer i appreciate it
