Anyone using 10w40 oil?
Old Mar 30, 2017 | 08:39 AM
mclasser's Avatar
Car uses about a quart every 6k miles with 5w30, which isn't much but I'd like to see if a summer run with 10w40 helps.
10w40 users, please feel free to share your experiences.
Old Mar 30, 2017 | 10:00 PM
Child_uv_KoRn's Avatar
Bad *** Newb
0w40 mobil or castrol
Old Mar 31, 2017 | 09:57 AM
DennisMik's Avatar
I use 10W40 year around. Have done this for years and years.
Old Apr 4, 2017 | 05:52 AM
maxinout93's Avatar
i only use 10-40 between oil changes or only when i have to add some. Lately 5w30 has been lasting me alot longer between oil changes after replacing the leaking oil pressure swich.
Old Apr 8, 2017 | 10:06 AM
kauaiwyatt's Avatar
I use the high mileage 10-40 year round, but it still burns off a quart between oil changes
Old Apr 9, 2017 | 02:01 PM
FanaticMadMax's Avatar
I used to use 10w30 for years til now I have been using 5w20 synthetic to get better fuel economy.
Old Apr 10, 2017 | 09:55 AM
Prophecy99's Avatar
can u tell /feel the difference from the recommended 10w30 vs the 10w40 ?
i was doing 5w30 for a while, and then the same damn oil change shop changed me to 10w30 currently...
i thought 5w30 was a lil nicer for oil consumption
Old Apr 10, 2017 | 10:26 AM
DennisMik's Avatar
I can't tell any difference. I'm not a performance person, all I want is a reliable car that is to drive. My original reason for going to 10w40 was because I was doing a lot of highway driving and wanted the better protection for the sustained higher rpm on a hot engine.
Old Apr 10, 2017 | 12:07 PM
mclasser's Avatar
5w30 is the recommended weight, but the manual says 10w30 & -40 can be used above 0F.
Old Apr 19, 2017 | 07:06 AM
Prophecy99's Avatar
ok kool ! i just wanted to know the reasons for weights... i need to study oil mroe i guess. im not much a performance person either, just wondering if u felt it in the pedal or anything. thanks for input !
what do you like to use? is 10w preferred by you?
Old Apr 19, 2017 | 08:41 AM
Tarzan's Avatar
Consider using high-mileage oil, if you are losing it through the valve guide seals, it may help.
Old Apr 19, 2017 | 08:46 AM
maxiiiboy's Avatar
Why not 0w40?
It lubricates better at start-up (low temperatures, and I mean like 72'F), and is the same as 10w40 at high temperatures .....
Wallmart sells it for ~$25 for 5L jug.
Old Apr 19, 2017 | 04:03 PM
mclasser's Avatar
I've mainly been using 5w30. I looked at UOAs and these VQ35s tear up oil for some reason. A 40 wt should protect against shearing.
Originally Posted by maxiiiboy
Why not 0w40?
I used M1 0w40 once and was impressed by how smooth it made the engine run. The peeps over on BITOG say on cold starts, an oil burner will burn a 0w more easily than a 10w. This is why I want to try out 10w40.
Old Apr 19, 2017 | 04:52 PM
Bad *** Newb
It doesn't make much difference in my experience. If the oil is a similar viscosity at temp and similar base stock (it's not b/c 0W has superior stock), then it would burn about the same.
If there's not precat damage, then the burning is from valve stem seals. I just swapped another motor and guess what? The exhaust valves were wet and had tons of carbon from the oil leaking down (engine had sat a long time, too, that's how much oil was still on them).
Old Apr 20, 2017 | 05:35 AM
Prophecy99's Avatar
so my burning is from teh valve stems seals.... what else should I know? oil catch can worth anything in that specific case?
am I good at staying at 5w30 vs 10w30 ??
Old Apr 20, 2017 | 05:36 AM
Prophecy99's Avatar
thanks for your input ! 5w30 has been feeling nice too along with TCW3
Old Apr 20, 2017 | 12:19 PM
Bad *** Newb
Delete PCV and that solves oil in the intake. You will burn some from blowby, but those stem seals are so ****ty. I could engine brake for a few seconds (pull some sweet vac), then upon acceleration, it'd blow a thick blue cloud. Rings aren't gonna do that.
Old Apr 20, 2017 | 03:26 PM
Donkeypunch's Avatar
broken pistons/rings smoke is going to pour out the valve cover
Old Jun 20, 2017 | 02:49 PM
mclasser's Avatar
For anybody that cares, I decided to try MaxLife 10w40 for the summer. 2k miles of mixed driving and dipstick is still full. Engine purrs like a kitten. MPG is still the same as before.
Old Jun 21, 2017 | 06:40 AM
uptownsamcv's Avatar
I run Shell Rotella 5w-40 in everything, even my motorcycle... it's good stuff
Old Jul 2, 2017 | 07:54 AM
ffcbairn's Avatar
0w-30 in winter, 5w-50 in summer.
