Squeaky Clutch Pedal - 6 Speed
Old Apr 1, 2017 | 01:02 PM
jsmith24's Avatar
Hi guys,
I DID search, until I got a headache. I even thought I found someone who said they did a write up on this, but the links they gave for the .ORG are now redirecting to completely unrelated things. At any rate -
My clutch pedal squeaks, has for a long time, but now I want to pull the assembly and replace the bushings. I *hear* that's probably what's causing the noise.
Does anyone have a write up for the 5th gens? I saw one for 3rd gens, but that doesn't seem to match up at all.
Now, if the assembly doesn't have to come out and someone knows a better way, I'm all for that, too.
Thanks,
Jack
Old Apr 2, 2017 | 08:09 AM
Derrick2k2SE's Avatar
I've had the assembly apart but it's just one of those things you have to do. There's really not that much to it. The spring can be a pain.
I didn't pull the whole assembly. I just replaced the bushings in the car.
I made some bushings out of brass on my small lathe. Works great.
You could get a spray can of white lithium grease and hit it with that. That should quiet it down for a while.
