Clutch Bleed
Old Apr 12, 2017 | 07:24 PM
wellshii19's Avatar
Clutch Bleed
Service manual states it in a fairly simple manner.
I see also an upper bleeder,anyone use this as well to bleed?
https://maxima.org/forums/5th-genera...ring-back.html
The Service manual shows a little picture with both bleeds stating to use both.
I can't seem to find the other bleeder valve.I'm assuming it's between the tranny and air box?
Wouldn't I just be able to bleed from the top valve using vacuum?
Who's a pro at this? I have never done a clutch bleed.
Old Apr 13, 2017 | 08:28 AM
Derrick2k2SE's Avatar
Don't screw with the upper bleeder. The 02/03 has a really screwy system that can trap air all through it. A lot of us just replace it with a straight line.
If you want to bleed it just use the bleeder valve at the slave and do it like you would the brakes. You can use a vacuum.
Old Apr 13, 2017 | 11:53 AM
wellshii19's Avatar
Right on. I'll do that. Thanks bro.
Old Apr 13, 2017 | 02:33 PM
krismax's Avatar
Father of the 00 VI
yes like derrick said replace it with this. fixed
http://www.technafitstore.com/Nissan...p/nccl-201.htm
Old Apr 13, 2017 | 04:25 PM
https://www.technafitstore.com/category-s/44682.htm
That line only replaces the soft rubber line and leaves the tangled maze of hard lines.
There is a member here who has a store selling a full SS replacement line from the master to the slave. I can't remember who though.
Old Apr 13, 2017 | 05:35 PM
krismax's Avatar
Father of the 00 VI
ok here it is full line.
or
Master to Slave Cylinder Complete Clutch Line Kit for 1995-2001 Nissan Maxima
on ebay
Old Apr 14, 2017 | 07:28 AM
wellshii19's Avatar
Awesome thanks guys
Old Apr 15, 2017 | 10:53 PM
krismax's Avatar
Father of the 00 VI
Awesome thanks guys
ok i found it,this is the cheaper one made by nisperformance
http://www.nisformance.com/One-Piece...hhoseclear.htm
