2003 SE alignment problems after front end work
I have an issue with my 2003 SE pulling fairly hard left. I had my local mechanic replace the front rotors, brakes, tie-rods, end links and struts all the way around (new springs as well), new right side motor mount.
When i got the car back I noticed the car pulling left pretty severely so i took it back and he tried to align it but says he cant get it aligned. He has since replaced the 2 front struts twice thinking the front struts were the problem. The car still pulls hard left and he does not know what to do.
I am posting this for any insight from you pros out there with these cars? It was driving perfectly straight before all of the work but it was clunky and I like tight cars. The car is tight now but PULLS LEFT. I need to get this fixed so I can then get new tires.
If you can give me some direction to go in that would be great!
Thanks,
Ken
Thanks,
Ken
Unless you specify a master tech or someone with years and years of experience that knows what they are doing.
Take it to an actual suspension shop that specializes in this. Google is a great resource for reviews on shops.
Yeah, forget the dealer. A good underbody/alignment shop will be better since that's what they do all day.
Like wellshii19 said. Look at Google reviews and call a few shops to see what they think about your situation.
To toss it out here did your mechanic consider inter tie rod especially the left side. Mine is going bad but I am in alignment enough to not wear the tires.
Its a random guess but makes sense and since you already replaced said parts. It cant be too many things. And after replacing struts and outer tie rods everything else is so tight now you would notice the inner being bad, especially since it wont align. same thing happened to me.
I don't understand why mechanic didn't require an alignment. Most will when doing that work.
I did tie rods and control arms on my car and saved money but due to vehicle needs and time I got stuck having a gap between the two part replacements and when finally aligned I had tires worn incorrectly. Can't remember how many miles this was, but it happened nonetheless.
Get it aligned and you should be just fine.
I think you're on the right track.
It sounds like you have a straight mechanic but he probably has a very basic alignment setup to work with.
A specialist with the right equipment may be able to align it even with the bad tires. They'll also be able to find any other worn parts which could cause the issue.
