Tranny Smokes up hills
Old May 5, 2017 | 08:35 PM
00MAXI's Avatar
Tranny gets waaay to hot going up hills and lets off that burnt fluid smell. Sometimes you can even see smoke. I've checked fluid and it's still relatively pink. The car has 300k lol but it's been meticulously maintained (thanks to this board). Should I just change the fluid out anyway?
Old May 5, 2017 | 10:35 PM
mydecember1985's Avatar
And you're sure it's the tranny and not your rack/pinion or valve covers?
Old May 6, 2017 | 01:24 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Yup. It sounds like the extra heat from load is burning off oil.
As if you would see smoke from the tranny...and if it was overheating the fluid would be burnt (in color, too).
Old May 6, 2017 | 04:47 AM
Derrick2k2SE's Avatar
I have to agree with the others. This sounds like an oil leak.
Are you checking the temp of the tranny or just seeing smoke?
Old May 6, 2017 | 07:25 AM
maxinout93's Avatar
I agree if it was the tranny then the fluid would def be burnt and a dark brown color, or black. Had my 3rd gen tranny go out and the fluid was def burnt. Maybe you are seeing oil or power steering fluid.
Old May 6, 2017 | 12:37 PM
00MAXI's Avatar
Replaced Valve Cover seal but there is a rear main leak that I'll probably never fix
Old May 6, 2017 | 07:25 PM
maximatech12's Avatar
anyone go for the Remanufactured tranny from Rock Auto?
Old May 6, 2017 | 08:54 PM
It's a lot of work.
Old May 7, 2017 | 01:56 PM
AaronL's Avatar
Originally Posted by Derrick2k2SE
It's a lot of work.
Is that different from a valve cover gasket leak? Asking for a... friend
Old May 7, 2017 | 07:09 PM
cornholio's Avatar
yes
Old May 7, 2017 | 07:39 PM
SubwayVQ's Avatar
It is a seal at the opposite end of the crankshaft pulley, so you need the transmission and flywheel or flexplate removed to access it.
Old May 7, 2017 | 08:21 PM
Bad *** Newb
And then you realize it's the half-moon and you need to take off the oil pan
Old May 7, 2017 | 09:45 PM
SubwayVQ's Avatar
Yes, that too lol
Old May 8, 2017 | 02:26 AM
00MAXI's Avatar
So you guys think the smell is from the rear main leak? The oil on the exterior on tranny getting superheating and smoking?
Old May 8, 2017 | 08:20 AM
Yeah.
Pull tranny, Pull flywheel, Pull lower and upper oil Pan (which requires removal of Y-pipe.
Old May 8, 2017 | 08:29 AM
Hard to say without looking at it. Usually the rear main drips down from the bottom and covers the underside of everything downwind.
Have you seen the tranny smoking? It shouldn't get hot enough to burn off oil like that. If the top of it is covered in oil it's coming from somewhere above it.
My guess would be leaky valve covers dripping down onto the exhaust.
