Ac control lights dont work
Old May 15, 2017 | 11:51 AM
Maxboy23's Avatar
I drive a 2002 nissan maxima gle the ac control lights stopped worning but it's only the middle bitton , the mode and the fan spees button the left side works fine is it im not sure if its a fuse or maybe they just burnt out
Old May 15, 2017 | 01:23 PM
SubwayVQ's Avatar
Does your A/C still turn on? If so, then the bulb is burnt out. If not, you will have to diagnose why not.
Old May 15, 2017 | 02:12 PM
TallTom's Avatar
burned out. They are available from the dealership and there is a how to somewhere on how to get to them to swap. The old ones will practically fall out while the new ones will be a really tight fit.
Old May 15, 2017 | 04:42 PM
Maxboy23's Avatar
The ac works i have wanted to switch the color to like red instead of white now i have an escuse to is there like a diy on the forums?
Old May 15, 2017 | 05:22 PM
SubwayVQ's Avatar
It shouldn't be that hard, just pull apart the climate control module and find the button/bulb you're looking for. It's more than likely held together with plastic snaps or small screws.
Old May 15, 2017 | 06:29 PM
Maxboy23's Avatar
What bulbs do i get
Old May 15, 2017 | 10:47 PM
SubwayVQ's Avatar
What bulbs do i get
If only a utility existed that allowed you to type in anything you wanted and get millions of suggestions.
Old May 16, 2017 | 06:39 AM
Prophecy99's Avatar
common problem and how to thread, please search . a good search would be ACC unit lights
Old May 17, 2017 | 01:26 PM
The_Fixer's Avatar
Like this
Attached Thumbnails Ac control lights dont work-photo153.jpg   Ac control lights dont work-photo849.jpg   Ac control lights dont work-photo279.jpg
Old May 17, 2017 | 08:31 PM
ajahearn's Avatar
I do want to warn you that replacing the bulbs can end up in some of them not working. If its really important to you, then order extras.
Old May 18, 2017 | 04:27 AM
FlaMark's Avatar
Take a pic. and post it. I think i have the same problem.
Old May 18, 2017 | 07:31 AM
Prophecy99's Avatar
yes replace all 3 while u have it opened up,
i did this already , adn same two burnt out again cpl years later, i think theres a more long term fix w like a solder , i feel one member figured out the real cause of the early burn outs.
Old May 18, 2017 | 08:17 AM
The_Fixer's Avatar
the problem is the contacts on the board clean them with sand paper first
and the Eagles Suck
Old May 18, 2017 | 08:19 AM
The_Fixer's Avatar
Old May 18, 2017 | 06:07 PM
Maxboy23's Avatar
The fixer do you do custom led work?
Old May 19, 2017 | 06:46 AM
Prophecy99's Avatar
and the Eagles Suck
thanks for that !! soudns right !! i need to replace mine a 2nd time and have blubs waiting to be put it, but its just blah ....for a cpl light bulbs rip out half of ur dash...
i need to get rid of that, i dont even like pro sports any more ! missed last two super bowls w pride.
Old May 19, 2017 | 02:00 PM
The_Fixer's Avatar
Yes i do
https://www.facebook.com/groups/LedSwaps/
Old May 19, 2017 | 04:36 PM
The_Fixer's Avatar
Also the aftermarket bulbs your most likely getting from SBL they are not the correct size i have swapped out hundreds of sbl leds for the ones i make and i use 100% oem bulb holders.
Old May 22, 2017 | 06:05 AM
Prophecy99's Avatar
i did OEM twice, no one said aftermarket
Old May 22, 2017 | 06:50 AM
The_Fixer's Avatar
