Window problems
It sounds like all the master switch is no good. I've had the same problem how the maxima electrics work from experience is that when on part of the system doesn't work the whole thing doesn't work. Try to replace all the switches, just note if you get them used something might be wrong with it so test it on your car before you leave the place. If that doesn't work it could be your fuses or relays are broken or the motors are all bad. Hope my advise helps.
Try e-Bay; you should be able to get a replacement switch from a junk yard place for about 1/4 of the cost of a new switch.
