2000 V6 engine issue
Old Jul 26, 2017 | 12:15 AM
Paul Sanders's Avatar
we have a 2000 V6 auto, randomly the engine will loose pretty much all power, have to pull over, turn ignition off for at least a cpl of seconds and then restart.
When this happens idle speed is way up (1500 or so) no accelleration.
Anyone have any clues as to what the problem may be ?
Also, the ECU, what sort of connection does it use (Obd2?) and where would the connection be located ?
Thanks in advance
Old Jul 26, 2017 | 12:58 AM
BronxSleeperMax187's Avatar
This is on the transmission on the here
change it might fix your problem.
Old Jul 26, 2017 | 01:02 AM
Its called the revolution speed sensor, auto zone has em but they might tell you its the one that has a little wheel on it, thats a different speed sensor, make sure you get the one in the pic above. They both go into the tranny but the one you want is that one...good luck
Old Jul 26, 2017 | 08:54 AM
SubwayVQ's Avatar
Try cleaning the MAF sensor.
Old Oct 1, 2017 | 02:47 PM
thanks to all, part finally arrived, 10 minutes to install it, car runs like it is meant to now
