Brakes sticking, replaced caliper, bracket, pads, still sticking
Old Sep 10, 2017 | 02:53 PM
flames101sully's Avatar
On the 2003, the front right brakes keep sticking. I replaced the caliper, the bracket (One of the bracket pins on old one was seized), and the pads. Bled the brakes and it was fine for a couple of kilometers, then completely sezied again. Any ideas? Master cylinder?
Old Sep 10, 2017 | 06:31 PM
mclasser's Avatar
The brake hose could've collapsed internally.
Old Sep 10, 2017 | 06:41 PM
That would make sense. Would it show any symptoms when bleeding the brakes? Becuase the fluid bled fine.
Old Sep 11, 2017 | 08:08 AM
Tarzan's Avatar
By sticking do you mean one caliper is dragging?
Old Sep 11, 2017 | 08:13 AM
Yes, the front passenger caliper is not dis engaging. So I replaced the caliper and thought it was fine, but it quickly began sticking again.
Old Sep 11, 2017 | 09:21 AM
DennisMik's Avatar
Have you REPLACED both caliper slide pins?
http://contentinfo.autozone.com/znet...H5075/image/4/
Old Sep 11, 2017 | 09:35 AM
Derrick2k2SE's Avatar
A faulty line will still bleed fine. Pressing the pedal produces a lot of force. There's nowhere near as much causing it to release. It can essentially become a one way valve.
Replace the rubber brake line and the problem will most likely go away.
Old Sep 11, 2017 | 09:49 AM
Alright, will try that later this week
Yes, both were replaced.
