Headlight problem
Old Sep 19, 2017 | 06:23 PM
Peytop's Avatar
Headlight problem
I'm currently having an issue with my drivers side headlight, low beams do not work, but high beams do. I have already switched out the bulb and have even swaped out the passengers bulb with the drivers. I'm still having the issue. I would assume it might be a fuse, my problem is, is that I'm not savy or have access to a lot of tools. I do not know which fuse specifically to check. I would also guess that if it's not the fuse, it's the Relay, but again I don't know which one to go after. I don't know what the issue cause would be past this however. If someone who knows more could advise what to look for, it would be appreciated.
Old Sep 19, 2017 | 09:36 PM
SubwayVQ's Avatar
What year? Because 00-01 have halogen and 02-03 have HID.
Old Sep 19, 2017 | 09:51 PM
Peytop's Avatar
It's a 00 model, practically stock with everything in/on it.
Old Sep 19, 2017 | 10:02 PM
DennisMik's Avatar
There is a fuse for the right side and a different fuse for the left side. Each fuse powers both the high beam and low beam for that side.
The headlight switch is a more likely cause.
