2000 Maxima 3.0 Ignition Condensor
Old Oct 28, 2017 | 01:41 PM
CRizz's Avatar
Been through all the T/S and I've come down to a Ignition condenser that is out of tolerance which is giving me a code 1320.All new coils and plugs and the car runs great but that code is driving me nuts and want to get rid of it.Went to dealer to get a new condenser and they could not locate a part number and said its part of the harness and only can get it with harness.And yet factory service T/S manual tells you to replace only the condenser.Can anyone give me a part number or where I might find a replacement?Thanks.
Old Oct 28, 2017 | 02:34 PM
ackack's Avatar
Nissan's part number is 28351-89901 https://www.courtesyparts.com/oem-pa...oil-2835189901 I got one from here not too long ago. That was the only code showing at the time, and I tried it ($8 was inexpensive anyway) to avoid replacing the coils. Cured that code, but within a week or so, I had to replace the coils anyway.
Old Oct 28, 2017 | 06:18 PM
Child_uv_KoRn's Avatar
Bad *** Newb
free at junk yard
Old Nov 25, 2017 | 06:00 AM
Jeremiah Milford's Avatar
Can't find
I can't find my ignition coil condenser on my 2000 Nissan Maxima
Old Nov 25, 2017 | 11:33 AM
maximatech12's Avatar
The thing about that is if go to check the coil ground from the connector to the terminal on the TC cover, you need Mega ohms.
If you remove the connector and check that circuit you will get a specific resistance.
