Gas smell
Old Nov 28, 2017 | 08:15 AM
2damax's Avatar
Gas smell
2003 maxima SE with 205k. This car has been a beast!
So I have 2 issues which I believe are unrelated but who knows. When I get out of my car after a drive I smell gasoline. I would say it is mildly strong. No puddles or anything to be found. Before I start digging around, are there any common areas in this car to check? The second problem is my fuel gauge. Even though my gas is near empty it may read 1/4 tank. Then I will drive it in a couple hours and it will say empty. And then back again.
i will likely postpone this until warm weather comes back but I’m curious if anyone has experienced this and if people have a common solution.
thanks in advance for the help everyone!
Old Nov 28, 2017 | 12:29 PM
MichMaxFan's Avatar
Have you had any work done on the car lately? A hunch would be somebody serviced the fuel system, damaged the float mechanism when removing or reinstalling the pump assembly, and didn't properly seal it into the tank.
That could all happen in one repair job and then now gas leaks down the side of the tank and you smell it. HOWEVER, you would almost certainly smell it inside the car if it was leaking at the pump assembly.
That's where I would check..under the rear seat or under the car for dribbles on the tank. Beyond that, I don't know.
Hope it helps you.
Old Nov 28, 2017 | 07:34 PM
DennisMik's Avatar
The gas smell could be the filler neck rusting out.
Old Nov 29, 2017 | 03:35 AM
2damax's Avatar
I will pull the seats out and see what happens and check the filler neck tomorrow. This car hasn’t been worked on lately. Like I said, it has been a beast.
Thanks for the help guys
Old Nov 30, 2017 | 02:59 PM
Will's Avatar
The fuel gauge is a gauge cluster issue, so try to find a used one that works.
The fuel smell could be from a rusty fuel filler neck, or simply just from age, where the rubber fuel lines from your engine bay have micro-cracks that allow fuel smell to seep through. When it's cold, the rubber contracts and hardens, so If you smell it in the car when cold, when you first turn on the heat, that's the likely cause, and it likely goes away when warm once heat from the engine softens the rubber.
Old Dec 1, 2017 | 04:50 AM
MadMax07SL's Avatar
What makes you so certain it's not the float sensor in the tank? That's more often the problem I would think.
