Crank no Start.
Old Dec 6, 2018 | 12:32 PM
VR6toVQ35's Avatar
Crank no Start.
All was well until I tried to start it yesterday morning and it wouldn't start. It cranks really nice but refuses to start. I have codes for my gutted precats , evap codes and O2 heater circuit but car has always run fine with those codes. I did a headunit replacement a few day ago so I checked for blown fuses but everything looks good. I had a friend check the battery and starter voltages he said it looked good. I just replaced the camshaft Sensors but still no go. Am now convinced its the fuel pump, is there anyway to test it without a multimeter? Can the pump die with no warning signs? any suggestions?
Old Dec 6, 2018 | 09:45 PM
maxiiiboy's Avatar
Make sure the red security light is not ON when cranking (if it is, you have a security/NATS problem).
What kind of camshaft sensor did you use? Go with Hitachi only ....
Finally, fuel delivery (pump, or pressure regulator) could be at fault. The FSM (pages EC-54, EC-55) shows you how to check fuel pressure but you need a pressure gauge.
Old Dec 7, 2018 | 12:26 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Unplug crank sensor. It fails more than cam (they usually cause shut off while driving but start fine). If the plugs are wet, then it won't be fuel. If you pull the plug you'll find there's no spark when cranking.
Old Dec 7, 2018 | 09:21 AM
VR6toVQ35's Avatar
I can rule out NATS then, last place I want to go is the STEALERSHIP.
Old Dec 7, 2018 | 09:34 AM
VR6toVQ35's Avatar
Copy will pull the plugs and check.
Old Dec 9, 2018 | 10:31 AM
VR6toVQ35's Avatar
SOLVED. Turned out to be the fuel pump. Got a pump assembly from a scrapyard and the car fired up right away.
Old Dec 9, 2018 | 04:31 PM
Bad *** Newb
Pretty rare. You're a lucky one. /s lol
Old Dec 10, 2018 | 08:20 AM
cdoublejj's Avatar
after 14+ years them would have to be some well built pumps with quality the likes of which will never be seen ever again.
Old Dec 10, 2018 | 11:25 PM
Bad *** Newb
I have a 2001 model here with 260k miles on it. I've seen multiple others with well over 200k. They just don't fail often.
BETO6700
Jul 14, 2016 09:17 AM
EnriqueA32
Oct 13, 2013 12:56 PM
Maximeltman
Feb 22, 2010 10:32 PM
nissmax
Oct 1, 2007 04:54 PM
wunfstmax
Oct 27, 2005 11:34 AM
