Disabling the immobilizer
https://cimg3.ibsrv.net/gimg/maxima....8c8206241d.jpg
Is there anyone out the that can take my ecu and get rid of the nats ? I put a vq30dek from a 2000 maxima in my 1999 saturn sl2 and the nats it's making finishing this very difficult |
Originally Posted by Cronicjohnson
(Post 9201087)
Originally Posted by Violator
(Post 9201088)
Buy nissan data scan and a cable for it and make sure to wire up the nats the way it should be and program a key. That's really all you can do
My first question is did you wire up the fuel pump? And the power to the ECU(main power supply section in the EC portion of FSM). You'll need the ignsw and start signal to the ECM, power for the ECM, and the power to the fuel pump/fuel pump relay. This is only about a dozen or so wires, I think that probably covers it all for a 3.0 ECU to start, there's gonna be more for the gauge clusters and everything to work right
You're talking to the right person because I just swapped an 03 ECM into my 98 and had to wire up NATs and it looks like the same setup. 1 sensor (aka immobilizer) that reads the key. EL 323 is the diagram you want, it needs a 12v always on, 12v ign in on/start position, the ground, and the 1 wire that communicates with the ECU. Go to a junkyard with a Phillips screwdriver and get yourself the immobilizer and cut off the connector with it to make wiring easier At the bottom of the diagram the immobilizer is labeled as NATS IMMU, terminal 8 the white/blue wire is your 12v battery source, 7 red/yellow is your 12v on/start wire, orange goes to the orange wire in terminal 116 on the ecu(foldout section has pinout the color should match or you're looking at it wrong). The green/orange wire is just for the security light You wired up the fuel pump and everything for this swap but you couldn't get this part figured out? |
(Post 9201089)
There seriously no other way besides running all the security stuff? I dont even know where to start on writing that stuff in the diagrams on the fsm are not very helpful
Search for the nissan open source ecu flashing groups and see/ask, but I think only basic definitions have been completed on 3.0. |
(Post 9201100)
(Post 9201104)
Not unless someone has deleted the check in the ROM (haven't heard of it yet), but almost no one is even playing with 3.0 ECU, just 3.5. You would have more luck with 3.5 swap (nats delete already completed iirc).
(Post 9201120)
Even the 3.5 nats delete is prvate and you have to pay to get it done, still the problem I think is that he thought with the engine harness and computer that the engine would run. 2000 gauge cluster needs wired in if you want a speedometer, the engine harness/ECU needs powered, the signal to the fuel pump needs wired, nats needs wired, and theres 2 wires from the ignition switch. Obd2 data link connector will also need wired if you wanna even wanted to delete nats, read engine codes, and program a key
(Post 9201119)
I kept the factory wiring from the saturn to run the fuel pump lights etc. Just pulled the ECU harness and through the maxima harness in it.
Get an 01 ECU and Immobilizer and 01 key,prob get them for $150.Get the Nissan data scan 2 and connector (prob $70 )And that will be able to get rid of it.I am not sure if the 00 stuff will work with NDS2 .
BTW bypass the antifreeze fluid on the IACV if you don't want a burnt out ecu. |
Originally Posted by krismax
(Post 9201128)
(Post 9201129)
Is this a common thing to happen? Maybe that's why there is a section toasted on my ecu. But the car drove and idled fine perplexing
But even if you bypass it the antifreeze may be in the IACV and may still burn it over time. |
© 2024 MH Sub I, LLC dba Internet Brands
