Acceleration problem...(solved)?
Old May 28, 2019 | 10:14 AM
FlaMark's Avatar
Hey buds,
This week, i noticed my battery wasn't 'cranking' as strong as previous,...and today, driving home, the car lost acceleration. FIRST i thought MAF but now i'm thinking battery problems!
Does the battery have anything to do with acceleration ?
PS. i just went out to crank the car, and the battery is 'shur nuff' ----DEAD!
Old May 28, 2019 | 11:00 AM
freezer's Avatar
Check your alternator, or you'll end up with another dead battery pretty quick.
Old May 28, 2019 | 12:47 PM
FlaMark's Avatar
Ok...can Auto Parts store test that...?
What do i need to test Alternator?
PS. I just put new battery in...and car runs fine.
Old May 28, 2019 | 01:00 PM
freezer's Avatar
If there's no warning lights in the dash the alternator should be operating OK. A cheap OBD Bluetooth scanner and you can confirm your battery voltage. Or just use a multimeter to confirm that the alternator is charging. Should have more than 13 volts across the battery with the engine running
Old May 28, 2019 | 03:49 PM
Child_uv_KoRn's Avatar
Bad *** Newb
14 at a minimum
Old May 28, 2019 | 04:27 PM
FlaMark's Avatar
I just came back from the parts store....car started to die on the way back.
I tested the battery with a meter and it barely throws 12.16 (which means its not charging). I checked the connection and tightened it up.Then i jumped it and see if it would take a charge.
It doesn't look like its taking a charge...the battery remains at 12.40 with a jump on it...?
Does that make sense----would a battery 'cave in 20min' (even if alternator was bad????)
Old May 28, 2019 | 04:33 PM
freezer's Avatar
Sounds like an alternator problem. Is the belt on? If it is, sounds like your alternator is pooched. A battery is not intended to run the engine for a prolonged period of time. 20 minutes is a decent run time with no output from the alternator
Old May 28, 2019 | 06:19 PM
FlaMark's Avatar
Thanks man....yeah, i checked the belt,...and its good to go. The dayum alternator from Pepboys is bad. This one lasted a few years. NOT LOOOKING forward to changing it again....(Sigh)
Old May 29, 2019 | 09:44 AM
MadMax07SL's Avatar
Yeah, I hate to hear about people having problems with aftermarket parts like this. Starters, alternators, compressors, sure you can save a few going non-oem, but with the amount of labor it takes to install, it seems like a real buzz kill when the parts come up short. Sorry man...wish you the best of luck with the next one.
98MaximaLoveHate
22
Nov 28, 2020 10:09 AM
Mu33rto
Jun 29, 2011 07:13 AM
DuMKuH
Mar 4, 2010 01:26 PM
willard00
Nov 6, 2006 04:05 AM
la rata
Jan 8, 2005 09:33 AM
