P0420
Old Jul 28, 2019 | 09:17 PM
manilakid3's Avatar
P0420
This topic is all over the place but I'm still a bit confused since some info is misleading.
I'm getting a P0420: Catalyst system efficiency below threshold bank 1.
There are a three parts which are available on rock auto.
1. Front Precat
2. Rear
3. Center
Old Jul 28, 2019 | 09:20 PM
manilakid3's Avatar
I read that Cali law says I need to get the catalyst parts installed in an actual shop or the stealership? How true is this statement?
Thanks in advance.
Old Jul 29, 2019 | 01:47 AM
maxiiiboy's Avatar
That statement may be correct, but ..... If you install it yourself, and the code goes away, then you pass your inspection (as the inspection only checks for codes and incomplete monitors).
And who would know the difference ?
However, you may want to check that Rockauto will actually ship these parts to an individual like you or me (i.e., not a dealer or certified mechanic).
Old Jul 29, 2019 | 12:20 PM
manilakid3's Avatar
I'll contact rock auto and get back what the response is.
But what part do I replace for the above code?
Old Jul 29, 2019 | 07:41 PM
manilakid3's Avatar
A rep from rock auto emailed me back and said they do ship to residential addresses for CARB parts.
Old Jul 29, 2019 | 07:47 PM
manilakid3's Avatar
I have done the drive cycle twice. And now my catalyst says Complete for Emissions Readiness.
But during the drive cycle the SES light came on and the Pending Fault code P0420 is now showing as Current Fault Code thus triggering the SES light to come on.
Is this just a faulty O2 Sensor for bank 1? If so, I'd be willing to get the part and replace it but just want to make sure, I don't like to assume then find out later that the part was not the problem. Anyone gone thru this before?
Old Jul 29, 2019 | 07:49 PM
dizzykitty's Avatar
my guess is the front precat. I am an idiot tho so its anyone's guess.
Old Jul 29, 2019 | 09:10 PM
manilakid3's Avatar
There's a Service Bulletin for the 00-01 Maxima's. Does this pertain to the i30 as well?
My year and ECM P/N matches the numbers in the bulletin chart.
Old Jul 29, 2019 | 09:52 PM
manilakid3's Avatar
It's actually the long pipe looking thingy before the rear cat. I saw a chart that made things clear.
Old Jul 29, 2019 | 09:59 PM
manilakid3's Avatar
The yellow highlight is for the P0420 code. The Green highlight is for the P0430.
Old Jul 30, 2019 | 01:03 AM
maxiiiboy's Avatar
don'
Yes, I did. I went through the same thing 2 yrs ago.
Try to replace just the O2 sensor, but chances are it's your precat.
I am also in the Bay area. I was forced to replace both of my precats; expensive, but my car drives much better now. And I won't have to do this ever again.
Old Jul 30, 2019 | 02:06 PM
manilakid3's Avatar
What part/site did you get for the bank 1 cat? The long looking one.
Old Jul 30, 2019 | 07:39 PM
Donkeypunch's Avatar
since they just plug in the obd and check for codes, no actual smog tests, why not get defoulers to get rid of the code?
i've had mine that that for like 7 years. works good. mine have never been check. just a quick look over under the engine bay.
my precats are dead but not broken. i checked.
Old Jul 30, 2019 | 08:08 PM
maxiiiboy's Avatar
The picture in post #10 shows Bank1 precat highlighted in yellow.
My mechanic refused to do any gutting, so I just replaced the precat. Expensive.
You can try what Donkeypunch suggests - not sure whether you can still get defoulers, but check around.
Old Jul 30, 2019 | 08:51 PM
manilakid3's Avatar
In Cali they do an inspection/visual test to see if you did any mods. Emission laws might get worse from new laws coming down the pipeline.
Old Jul 30, 2019 | 09:10 PM
manilakid3's Avatar
Nissanparts is selling it for $859.
WTF !!
Old Jul 31, 2019 | 11:05 PM
manilakid3's Avatar
Are these the sensors I need for Bank 1?
Bosch 13374 - Downstream Rear
Bosch 15955 - Upstream Front
Old Aug 5, 2019 | 03:39 PM
maxinout93's Avatar
How much is the upstream bosh sensor?
Old Aug 5, 2019 | 05:31 PM
RA030726's Avatar
I'm nutty for Nissans
Upstream sensors are for adjusting the fuel/air mix.
Downstream sensors only monitor the effectiveness of the catalytic converter.
Sensors can go bad but the cat can be bad from other issues like fuel or ignition problems.
Old Aug 6, 2019 | 07:27 PM
manilakid3's Avatar
Bosch 13374 - B1S2 white wire Down Stream Rear $49.00
Bosch 15955 - B2S1 blue wire Up Stream Front $36.95
Bosch 13348 - B1S1 black wire Down Stream Front $64.78
Bosch 13350 - B2S2 red wire Up Stream Rear $64.77
I'm 99% sure these are accurate. It's frustrating because the comments on amazon are not all correct. I wanted to buy both rear sensors but 15955 is for the blue wire, it's the shortest wire since its closest to any of the sensors.
Old Aug 6, 2019 | 11:00 PM
User1's Avatar
I am running two of these upstream in my '03 with 2nd gen VQ:
https://www.ebay.com/itm/NEW-GENUINE...72.m2749.l2649
Old Aug 6, 2019 | 11:11 PM
User1's Avatar
Not a single one of those plugs looks anything like any of my '03 plugs. You're basing your information off of Amazon.com reviews?
I do it a little differently. Instead of relying on hearsay from highly questionable Amazon reviews, I start with OEM part numbers from nissanpartsdeal.com then cross-reference with other sources. This is the only research method I will use.
Old Aug 7, 2019 | 05:21 PM
maxinout93's Avatar
Thanks gonna order both upstream sensors not worried about the downstream unless they throw a code.
Old Aug 9, 2019 | 08:02 PM
manilakid3's Avatar
I looked at nissanpartsdeal but the OE parts # are not mentioned on RockAuto either. I also didn't get a definitive answer on this site as well.
Old Aug 14, 2019 | 08:53 PM
manilakid3's Avatar
Got the cat today. Both of the 02 sensor holes are covered and not threaded. Anyone else have a cat that came like this?
Old Aug 28, 2019 | 07:54 PM
manilakid3's Avatar
Finally got the CAT installed. Had to send to a shop since the bolts were way too rusted on which is expected for an 18 y/o car. Eastern CAT direct fit cleared my CEL and did 1 drive cycle to get the CAT ready. Didn't even have to change the 02 sensors. Passed smog as well
Eastern CAT $300
Labor $240
Old Aug 29, 2019 | 04:16 AM
Prophecy99's Avatar
sounds pretty reasonable ! thanks for posting your solution !
Old Aug 29, 2019 | 08:29 AM
Tarzan's Avatar
Bank 1 is firewall side.
Bank 2 is the radiator side.
P0420 is the bank 1 firewall side pre-cat code. The firewall side fails first around 100k miles give or take due to overheating from the lack of airflow behind the engine.
In this day and age the best bang for the buck is gutting and installing a sim if you cannot get away with a defouler.
Old Aug 29, 2019 | 11:47 PM
maxiiiboy's Avatar
Originally Posted by Tarzan
...... The firewall side fails first around 100k miles give or take due to overheating from the lack of airflow behind the engine. .....
Just a nit-pick: The B1/firewall precat is actually underneath the engine. This means it has as much - or perhaps more - cooling than the B2 precat which is just behind the radiator.
Old Aug 30, 2019 | 06:48 AM
Prophecy99's Avatar
another nit pick, in my opinion it's not a thing where they fail at a certain time.....i wish there was sense to when or why they fail, i feel the more you beat on a car the more heat you will put on the cat material.
i gutted my cats and they were 100% yes 100% intact at 168k miles...so ....yea
Old Aug 30, 2019 | 02:27 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Ok, grandma, we get it. Now, get to your dialysis appointment. XD
Gutted some with 95k and not driven hard...front was chipping away.
Old Sep 3, 2019 | 05:50 AM
Prophecy99's Avatar
RLW001
Jun 20, 2008 10:21 AM
CyMax
Nov 17, 2005 03:23 PM
99-max-ster
Aug 16, 2005 04:01 PM
