DTC P1336 solved!
Old Aug 25, 2020 | 04:22 PM
Amave's Avatar
DTC P1336 solved!
So since i bought the car back in 2010 it had the constant DTC p1336 crank position sensor POS. , it never really was a problem in the past, since the engine ran good, it had a hard start but always started up every time, and other than the DTC i never had a problem. Well i decided to reseal the oil pan since i was passing it on to my son who is going away to college i figured if i do more work on it, the less he has to do to it when it comes time to fix it.
I resealed the oil pan and when i removed the pan low and behold i see my problem is the signal plate that is attached to the flywheel.
The kid i bought it from had the transmission and clutch replaced so when i got it the clutch was new so i had no reason to replace it , and if i had it long enough i am sure i would have had to replace it eventually. .
Old Aug 25, 2020 | 04:25 PM
Amave's Avatar
You can see the signal plate is damaged on the FW , i just wanted to share what i found just in case anyone has the same type of DTC and everything else checks out
Old Aug 25, 2020 | 04:27 PM
Amave's Avatar
And my beloved 2000 Maxima
Old Sep 25, 2020 | 04:41 PM
Amave's Avatar
Originally Posted by benmickel
Well I replaced just about every sensor I could, the cam and crank sensor twice, the second time with Motorcraft parts and this code still kept coming back. Even replaced the alternator and some wiring, no change. I got lucky and found a same year 08 CVPI with cruise control in a local wrecking yard, and grabbed the ECU. Swapped the ECU and everything's fine since a few weeks. Oh well live and learn..
snaptube vidmate word to pdf
As long as it got fixed, thats whats important. I knew it wasn't the ECU because i did all of the electrical checks according to the FSM so the only thing left that was not verified was the flywheel signal plate , which i found when i resealed the upper oil pan.
TomZ
Nov 16, 2009 02:59 PM
Turbobink
51
Jul 9, 2008 11:32 AM
