Variable Timing Selonoid ???
Old Nov 15, 2020 | 06:13 AM
Balkins's Avatar
My car is dying when i brake and pull up to a stop light. I ran codes and got the message (Variable Valve Timing Selonoid (p0012, p0021). VVTS. I Recently changed the Front Cam Sensor. Car has 150k on motor and runs well.
  • My mechanic says 'it coud be CAMS are moving out of sync due to LOOSE TIMING CHAIN"
  • Does this sound right?
He said the VVTM would be triggered when this happens?
Anyone run into this before?
~Thanks in advance
Old Nov 15, 2020 | 05:48 PM
freezer's Avatar
Check the wires going to the solenoid(s) to ensure they haven't shorted. Very common failure on these engine harnesses. Will fry your ECU too if not repaired, if it hasn't already.
Old Nov 16, 2020 | 05:37 AM
Balkins's Avatar
Whoa. Thanks man.
How would i know if ECU has gone bad?
densetsu
19
Oct 18, 2009 01:22 PM
92 Max
Mar 22, 2006 07:08 PM
Spipedong90
Jan 24, 2003 01:16 PM
