How much oil should drain out during change.
So I got a 5th gen maxima (2003) got it about a year ago 3rd time i've changed the oil and every time only about 1.5qt drains out even though specs say it holds about 4.5qt
Is this normal ?
And now before you ask it's not mixing in with the coolant and there doesn't appear to be any leaks.
(update filled with 2qt new oil and after sitting several hours) it's now overfilled according to the dipstick registers slightly higher than the H mark though the engine is cold.
Is this normal ?
So I got a 5th gen maxima (2003) got it about a year ago 3rd time i've changed the oil and everytime only about 1.5qt drains out even though specs say it holds about 4.5qt
Is this normal ?
And no before you ask it's not mixing in with the coolant and there doesn't appear to be any leaks.
Is this normal ?
Any chance a bad VVT solenoid could be trapping the other 3 quarts.and still cause the dipstick to register as full because not a single drop has hit the ground and I generally only drive maybe 5 miles a day. the car spends more time idling during my lunch breaks at work than it does moving.
Was thinking there could be a blockage stopping the oil from pouring out even when the oil is hot because this last time I changed it I only added the 1.5qt that came out and no oil light lit up on the dash. Dunno where it would be though.
Early 3.5s are know to burn oil. I have changed oil where only 1.5 qts came out. The oil light did not come on and there was a knocking sound. It happened again within a few months, it's burning oil big time. It is usually a sign the catalytic converters are falling apart and have scored the cylinder walls. The dip stick also gives false readings. You have to wait and let the oil completely settle.
Well as I said before I drained 1.5qt (everything that would come out by removing plug/filter. I then proceeded to add 2.5q and now that it's had a few hours to settle the dipstick shows well above the full mark (about a centimeter above the H (on a cold engine)
previous owner could have just picked up any nissan dipstick and shoved it in there, they all look the same but could have different lengths
Nor would the EVER check the level. That's wasted time.
proguitar04
Mar 2, 2004 08:24 PM
