Bizarre Electrical Issues After a Dead Battery
Old Jul 16, 2022 | 06:01 PM
gavin68's Avatar
I hope I can get some input on what might be causing some issues with my 2000 Maxima GXEL. It's an automatic with about 140,000 miles. No major mechanical issues until now.
About a month ago, I drove it about 650 miles across Texas, then back again (about 1,300 miles in total). A few days later, I drove another 650 miles back. No major issues during that time.
A week ago, I noticed that the Cruise Control was no longer engaging while driving on the highway. I assumed I had a brake light out, so I bought new brake lights. I was going to replace all three bulbs, but later found that all three bulbs were still working. I thought it was odd, but did not have time to troubleshoot it further. A few days later, I ran an errand and came home. When I turned the car off and got out, I noticed that all of my brake lights were permanently on. Now I was very confused, but still did not have any time to try to diagnose the problem. I decided to pull the brake light fuse and come back to it in a few days.
Last weekend, I put the fuse back in to test it and try to figure out the problem. I could not figure it out, but I also forgot to pull the brake light fuse back out. This caused the battery to completely drain. In the meantime, I did some research here on the forum and found that the probable fault was the rubber stoppers (Part # 465845P010, shown below). I looked around under the dash and, sure enough, both of the rubber stoppers were missing. I also noticed chunks of one of the stoppers on the floor. I ordered a replacement and replaced both stoppers.
They arrived on Tuesday 07/12/2022 and the installation was easy enough. At that point, I also found that I let the battery drain out and had to replace it. The auto part store covered it under warranty and gave me a replacement. I started up the car and tested it on the highway. Sure enough, the brake lights now worked properly and the Cruise Control is now working again. But, I also noticed that the brake pedal seemed more firm than usual.
Today, I drove into town and started experiencing issues. When I pulled out of the driveway, I found that the brake pedal was now even more firm than before. When driving on the highway, I noticed that the car seemed a bit slow to accelerate. I went into town and ran a few errands. When coming home, I had more serious issues. I could not get the car to accelerate beyond 48mph. I also noticed that the engine was revving upwards of 4,000 RPM, which is unusually high. It's usually around 2,800 RPM at that speed. At that point, I also smelled a burning smell.
I pulled over into a parking lot to examine the car. When I looked in the engine bay, I could smell some kind of burning smell, and there was a light smoke coming out of the engine bay. I checked the fluids, and found that the engine oil was fine. The transmission oil was a bit low, but I doubt that would cause a sudden onset issue like this. No fluids were noticeably dripping. Eventually, the smoke stopped. I turned the car back on and idled it. The engine temperature was normal, and the Check Engine light off. After a minute of idling, I went back onto the highway. This time, the car ran perfectly. I was able to get up to the 75mph speed limit with no issues.
I drove for another 20 minutes towards Lubbock for another errand, then went back home. When I was getting out of the city and accelerating up to 60mph, I noticed that the car began to shake violently. I suspected that this was probably another electrical issue, so I pulled over, turned the car off for about a minute, then started it back up again. When I got back onto the highway and got up to the speed limit, there was no more shaking. I drove for another 25 minutes without issues.
Almost right when I pulled into the driveway, the Check Engine light turned on. However, despite using two different scan tools, I could not find out what the DTC code was. Both scanners showed "MIL Light On", and all tests as "Ready", but no actual codes.
Now I am left scratching my head. Does anyone have any idea what is causing this? Did I screw it up?
Also, while it may be a moot point, has anyone else experienced both rubber stoppers failing within just days of each other?
Old Jul 18, 2022 | 12:20 PM
gavin68's Avatar
I had another look at it yesterday and noticed that the ground terminal connector was a bit loose. Not significantly loose. But I decided to replace the terminal connector as a precaution. Also sprayed rust remover on some of the points where the ground cable connects to the chassis. I reinstalled the battery and started it up. Didn't have time for a test drive. But, I noticed that the unexplained Check Engine Light went away. Will drive it later and see if it's any better.
Old Jul 23, 2022 | 06:45 PM
gavin68's Avatar
It's awfully quiet in here.
Anyways, I think I solved the problem. Turns out that my suspicion about an issue with the ground terminal connector was correct. As soon as I replaced that connector, no more issues have occurred. It was only slightly loose and could twist back-and-forth with some effort, but was not in danger of falling off. turns out that was not good enough. The new connector is tight enough that it will not move.
CraigsMax01
May 5, 2011 10:08 AM
midnight0045
Jul 9, 2010 07:48 AM
ComradeJew
May 7, 2007 11:16 AM
sadice
Jun 6, 2006 03:45 AM
mrb23
Nov 6, 2004 05:43 PM
