Random High Flow Cat Installation!
Old Feb 9, 2002 | 03:27 PM
MaxTuner's Avatar
OKay, I am confused what is the correct way to put the random cat on. Should the heat shield be facing up or down? Or it doesn't matter at all!
Old Feb 9, 2002 | 03:59 PM
Joe_R's Avatar
I believe the heat shield should be on top shiedling the floor pan.
Old Feb 9, 2002 | 04:02 PM
PCGuRu2K's Avatar
I just installed mines today and thats how I have mines installed..
Old Feb 9, 2002 | 07:16 PM
MaxTuner's Avatar
But how come the factory Cat has heat shield facing down? What's the deal?
Old Feb 9, 2002 | 07:27 PM
Joe_R's Avatar
You got a cat from the Pathfinder, complete with a skid plate. Kidding-Maybe someone else can shed some light on this.
Old Feb 9, 2002 | 07:36 PM
emax02's Avatar
The shield facing down is there in case you drive over dry grass, you don't want to start a fire
Old Feb 9, 2002 | 07:50 PM
Joe_R's Avatar
Old Feb 9, 2002 | 09:10 PM
MaxTuner's Avatar
So I should install the RT Cat with heat shield facing down then?
Old Feb 9, 2002 | 09:15 PM
emax02's Avatar
I don't know, I did not. I think the heat shield facing the car is more important then the one facing the ground. I am sure if the shield was supposed to point to the ground they would have put the stickers on that side. Did you read the instructions? It might say it in there, there's a how2 at www.5thgenmaximas.com too.
Old Feb 9, 2002 | 09:29 PM
Cumalot's Avatar
I didn't even bother to put the heat shield back on when I did mine.
Old Feb 9, 2002 | 09:32 PM
emax02's Avatar
My oem cat did not even have a heat shield.
Old Feb 10, 2002 | 12:12 AM
MaxTuner's Avatar
So the purpose of early 5th gen max with heat shield facing down is not to prevent causing fire!!! since the 2k1 or later, the cat doesn't even have heat shield on.
the instruction on 5thgenmaxima.com says facing down, and everyone else says facing up..that is why it confused me. Anyhow, i think for RT Cat, you need to face up due to that they put sticker and stamped number on the side that is suppose to face down! which makes heatshield faces up to the car.
thanks
Old Feb 10, 2002 | 12:22 AM
PhatGuy
Russ Vs Everyone else? No way!
How bout emailing RT or calling them?
Old Feb 10, 2002 | 12:32 AM
emax02's Avatar
My 95 and 98 had a heatshield aiming down and only down, the reason was to prevent a brush fire!!!
The 5th max skimps out on a lot of stuff, heres a list of my discovery's thus far. No HEAT SHIELD on the cat!!! No fuel splash guard(sand is all over my damn gas cap). There is not a brake dust shieled on my front roders.
Old Feb 10, 2002 | 07:28 AM
got rice?'s Avatar
aim it down.
Old Feb 10, 2002 | 10:16 AM
RussMaxManiac
The car has its own heat shield under the car to protect it from the cat. Everyone think for a minute. The stock cat did not hav a shield on top of the cat, it had one on the bottom to protect it from hitting the grass or something. The car has its own, you don't need one on top. The bottom is where you need it. Face the shield down.
thanks
Old Feb 10, 2002 | 10:17 AM
RussMaxManiac
My 2k1 had a heat shield on the cat facint down.
Old Feb 10, 2002 | 10:51 AM
emax02's Avatar
None on 2002's I guess Unless I got the skimp package .
Old Feb 10, 2002 | 11:02 AM
WILLSE's Avatar
u dont have a fuel splash guard on ur 2k2? i do!! i didnt on the 2k1???? just wondering!
will
Old Feb 10, 2002 | 12:42 PM
MaxTuner's Avatar
Correction, just got an email back from Dave at Randomtechnology. You should face the heat shield on top between the Cat and the floorboard.
I guess the sticker and stamped # on the Cat is there for you to follow, as according to their installation guide, you should be able to read the stamped # when installing it. Therefore, heat shield should face up!!!
thanks guys!
Old Feb 10, 2002 | 12:54 PM
RussMaxManiac
That's kinda funny how they say that, the instructions show it facing down. Sorry but the correct way is down unless you plan on having a fire under your car. Your car HAS A HEAT SHIELD under the body, there is no need for a 2nd one. The stock cat has no heat shield on top.
thanks guys!
Old Feb 10, 2002 | 12:59 PM
MaxTuner's Avatar
Could you post that instruction??
i dont' remember any instruction that comes with the Cat shows any diagrams?????
Old Feb 10, 2002 | 01:57 PM
UMD_MaxSE's Avatar
Got Bent?
doesn't really matter... the heat shield on my RT cat was loose so I ripped it off anyways... now I have none
Old Feb 10, 2002 | 02:13 PM
MichaelAE's Avatar
Did you experience any noise-level increase with the RT CAT?
Old Feb 10, 2002 | 02:18 PM
UMD_MaxSE's Avatar
Got Bent?
slight increase after 4k rpm.... but I like it I still have stock b-pipe and muffler though...
Old Feb 10, 2002 | 02:22 PM
MichaelAE's Avatar
Me too. I'm trying to keep the sound under control. That's why I just did cobymoby's intake...a little quieter I think. Thanks.
rbuswell
Nov 12, 2016 04:11 PM
Finkle
Sep 27, 2015 09:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
Team STILLEN
Aug 10, 2015 04:29 PM
