FSTB question
Old Nov 17, 2000 | 10:47 AM
sixman
Recently got a FSTB from Streetbeatcustoms. There is a slight interference with a bracket mounted near the right side of the bracket (about 8 inches from the end of the brace). I was thinking of adding a shim under the end brackets to raise it slightly.
Question is: If I use wahsers under the bracket (without shimming the entire bracket) will this put too much stress on the studs?
Old Nov 17, 2000 | 11:11 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Check with MaximaZero... he's installed it on his car.
Old Nov 17, 2000 | 11:26 AM
mdeal's Avatar
Is this the same problem with the Courtesy bar? Is the Streetbeatcustoms one really for a '99?
Old Nov 17, 2000 | 12:44 PM
sixman
The Streetbeatcustoms brace is for the 95-99 model. You need to remove a small portion of the air box mount for the driver's side bracket to fit. As far as I can tell, the bracket for the Courtesy brace has the same problem with the air box mount.
Old Nov 17, 2000 | 03:31 PM
punkdork's Avatar
I have the courtesy bar
I simply used my trusty hack saw to remove part of the air box mount. If you're still using your stock airbox you can even hide the cut.
Old Nov 18, 2000 | 12:04 AM
MaximaZero's Avatar
Needs non-Maxima Friends
mine is ghetto rigged. shoulda done it like for the courtesy, but i lacked a good hack saw. i did it the ghetto way and pried that sh*t off with pliars =P
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
