PR CAI Question???
??PR CAI Problem??
I just finished installing my CAI, but when i start the car, by where the filter it sounds like a vaccum, very loud, and the car sounds like it is dying when i start it. then if i step on the gas a little but, it revs up a little, then the car quickly loses power, sounds like it will stall but it dose not. I had to order a new MAF from Nissan, b/c i broke the other one, could this be my problem???? I get no service engine light.
Re: ??PR CAI Problem??
If you break the sensor, it means trouble... If that's the case, you should be seeing the Check engine light soon... Also, it'll cause your car to stall, similiar to the problems you're having now or even worse...
OH and it's normal for the filter to sound like a vaccum.. That's what the intake is actually doing... Sucking up air!!...
I snap the corners that was holding the bolts, so thay why i had to get a new one, Nissan guy told my that i had to bring it in to so they can reprogram it, can't I just reset the compter then it should be fine????
Unclejunebug
Apr 2, 2016 05:42 AM
