Optima Yellow Top
Old Mar 9, 2002 | 04:27 PM
MaximaZero's Avatar
Needs non-Maxima Friends
Optima Yellow Top
i can't seem to get the positive cable to hook up to the terminal on the battery. did i get the wrong battery, or do i need to modify something on the positive cable get it to connect to the terminal?
Old Mar 9, 2002 | 04:39 PM
MyownNismo's Avatar
Future Camaro SS owner
Re: Optima Yellow Top
Don't wreck it that's an expensive battery I had two in my other car.
Old Mar 9, 2002 | 10:52 PM
MaximaZero's Avatar
ttt, i really wanna get this battery in soon
Old Nov 16, 2002 | 10:35 AM
K Pazzo 6's Avatar
Anybody find out the answer to this.........If the Optima Yellow Top is not a perfect fit.....how do you get it to fit? Is there an adaptor or extension you have to buy too?
p.s. I ask b/c I'm considering one soon
Old Nov 16, 2002 | 10:43 AM
asu174's Avatar
Clay Aiken has fancy genitals
It should fit.
Old Nov 16, 2002 | 10:54 AM
PCGuRu2K's Avatar
You need to dremel off the plastic a little bit on the positive side. You see that piece that's preventing it from sitting flush on the battery..
Old Nov 16, 2002 | 10:55 AM
Tanman's Avatar
Mine fits, and that includes a terminal post for my amps, which normally gets in the way and makes it a tighter fit. What you need to do is cut some of the tie downs and electrical tape that's holding the positive cable to give it more slack and movement. If you had the Frankencar intake for the 2K-2K1 like I did, you would have already done this to get enough slack for the MAF wires. Be careful not to cut the wires, just the tape and hose sleeves to the left of the battery holding the wires in place. You can also try to shift the battery further back in the tray so the positive cable can reach.
Old Nov 16, 2002 | 10:59 AM
Tanman's Avatar
You mean dremel the battery cover?? I wouldn't do that if I were you!
Just cut the tie downs and get some slack for the positive cable, like I said above.
Old Nov 16, 2002 | 11:41 AM
PCGuRu2K's Avatar
Not the red battery cover.. The black plastic piece that sticks out and prevents the + cable from sitting flush. I guess I'll have to take a pic
Old Nov 16, 2002 | 03:11 PM
K Pazzo 6's Avatar
thanks tanman & PCGuRu2K for the answer
Old Nov 16, 2002 | 10:44 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
ya theres been problems with bigger batteries before..
i dont remember the exact fix.. but if i remmber correctly, you need to change the positive for a longer one..
or u can solder more wire for the existing one... or u can try to pull some slack...
lemme know what works for you..
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
Sep 27, 2015 08:37 AM
