Rough Idle, Sulfur smell, blinking service engine light
Old Mar 13, 2002 | 12:02 PM
SaVas's Avatar
Today i started my car, 2K GXE Auto, 47,500 miles, and noticed a mild shaking from the engine bay. Gave it a little gas and the shaking got heavier. AS I was driving to work, every time I would accelerate the car it would have that shake, and when I came to a stop when almost stopped it would shimmy a bit. Its not the tranny. A couple times I smelled a bad sulfur smell, then while I was at a light, the sulfur smell came back really strong, the service engine light began to blink for about 10 seconds, then the car idled fine and the service engine light went back out.
Anyone else have this problem?
Old Mar 13, 2002 | 12:21 PM
JMax2K's Avatar
Re: Rough Idle, Sulfur smell, blinking service engine light
Oxygen sensor possibly?
Old Mar 13, 2002 | 12:42 PM
SaVas's Avatar
Not sure. I guess thats one thing to have checked out.
Just seemed strange to have the problem then to have it just completely go away.
I wonder if it will be back when I go to start my car up tonight.
Old Mar 25, 2002 | 12:05 PM
Sandman2K's Avatar
Had the same problem... 2K SE with 46k miles.
Turns out it was bad coil packs. I'd seen the problem mentioned throughout the forum (usually concerning a TSB), and lo and behold, at 45k my "Service Engine Soon" light came on.
After putting it on the scanner, the local Nissan service department let me know that the code came back as a failure of 3 or more coils, and they replaced all 6 under warranty.
Now the car runs with no hesitation, and no stumble at idle.
Hope the info helps.
Old Mar 25, 2002 | 12:14 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Definitely coil packs causing it to misfire.
It can/will damage your catalytic convertor, so get them fixed soon.
Old Mar 25, 2002 | 03:16 PM
Y2KMaxGXE-R's Avatar
take your car on a highway and drive 20-30 miles at speeds above 100mph
disclaimer:
Old Jul 8, 2015 | 01:30 PM
02maxima76's Avatar
From: Southeastern Wisconsin, East of Madison, small town of Hustisford
Same problem
My car barley goes over 80mph lol. Once I hit 3k rpms it sounds like a Rev limiter is kicking in or something is plugged and preventing my car from further accelerating. Then it won't shift unless I let off the gas a bit. And 3/5 times my engine light blinks or codes p0420 or p0455 show up. Has new plugs and fuel filter. Putting new coils on today otherwise I think the Cat is plugged or just junk.
Old Jul 9, 2015 | 12:07 PM
foodmanry's Avatar
Da Roller Coaster!
Did you look up the P0420 code? It will confirm what you already think...P0455 code is completely different so you better be sure about your engine codes.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
