Brake ? on 2002
Old Mar 14, 2002 | 03:29 PM
timby01's Avatar
Brake ? on 2002
hey guys i just picked up a 2002 i had a 97 but my question is whenever i brake my steering wheel moves right to left is that normal for abs (being it's my first car with abs) or do i need an alignent or could it be bad rotors i know it's prob a stupid ? but if anyone could help me out
Old Mar 14, 2002 | 04:19 PM
ajahearn's Avatar
pull during braking
I've seen this happen when the alignment is out and also when a caliper is frozen. Its a matter of degree. Is it pulling a lot or just a little? A lot would make me consider the caliper. Your dealer will be able to tell you one way or the other. A frozen caliper should be under warranty. An alignment might be your bill.
ABS shouldn't be the cause of this problem. Do you notice this happening under hard braking and the ABS is kicking in? You can't miss the ABS kicking in, you can often hear it and you definitely feel it through the break pedal.
Old Mar 14, 2002 | 04:20 PM
Padsy's Avatar
Boost.....
Re: pull during braking
No problem here.
Old Mar 14, 2002 | 04:23 PM
xydavid's Avatar
Re: Brake ? on 2002
If the steering wheel is wiggling back and forth, I'd guess rotors. ABS shouldn't do that, and the ABS only kicks in when it senses a wheel might be losing traction -- not everytime you brake.
Old Mar 14, 2002 | 04:28 PM
timby01's Avatar
Re: Re: Brake ? on 2002
my luck hasn't been good with this car already i just got it on monday and when i went to start it the next morning dead battery now this i'm starting to wonder why i traded in my 97 but i still love the car
Old Mar 14, 2002 | 05:04 PM
griffy2k2max's Avatar
Re: Brake ? on 2002
Do you have a lot of truck traffic where you live? I've seen areas where the tractor trailors have worn grooves into the road that could cause the car to pull especially at the heavy braking areas near traffic lights, If you catch those grooves that could be a cause.
Just my 2 cents.
Old Mar 14, 2002 | 05:06 PM
timby01's Avatar
Just my 2 cents.
not really and i didn't have this problem in my 97
Old Mar 14, 2002 | 06:12 PM
D Love's Avatar
My mom was having a similar problem in her Accord. I think that it was because her alignment was off. Although I'm not 100% on this as it has been at least a couple of years since she had any problems.
Old Mar 14, 2002 | 06:28 PM
iwannabmw's Avatar
You can have this problem if one of your tires has a lower pressure than the others. The problem is magnified by the weight of the car shifting under heavy braking. Maybe one of your tires has a slow leak from a nail or something, or has the car always done this?
Old Mar 14, 2002 | 07:59 PM
ajahearn's Avatar
Re: Re: pull during braking
Originally posted by Padsy 02 6sp
No problem here.
Just to be clear, what I meant was past experience has shown alignment and frozen calipers can cause this problem. I have a 02SE that does not exhibit this problem and has not since I got it (Dec 01).
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
