Wheel Spin
Old Mar 17, 2002 | 02:16 AM
melteye's Avatar
Wheel Spin
How the hell do I get the max to stop screeching the tires when I press the throttle halfway in 3rd (auto).
And what exactly does LSD do? (limited-slip... not acid )
Old Mar 17, 2002 | 07:23 AM
Max_Gator's Avatar
Press the throttle less. Seriously.
If you are getting TOO MUCH wheel spin then you need to develop a feel for how much throttle to give it without spinning and without bogging. You also need to develop your feel for how much wheel spin is too much. That just takes practice.
Aside from that, check your tire pressure. If it is too high, you'll break loose a little sooner. You can lower it but don't go too much lower than recommended or you'll end up with too much wear on the outsides of the tire.
Or, you can get better tires or a tire/wheel combo that gives you a wider contact patch with the ground.
Old Mar 17, 2002 | 09:37 AM
2001SE's Avatar
how the h*ll can you spin in 3rd gear auto??
Old Mar 17, 2002 | 09:44 AM
My 4DSC
Re: Wheel Spin
<cough>bullshiet<cough>
Old Mar 17, 2002 | 09:54 AM
2001SE's Avatar
i am pretty sure he meant 1st gear
Old Mar 17, 2002 | 01:45 PM
melteye's Avatar
No, I meant 3rd... I live in Corona, CA if anyone wants to see for themselves.
I beleive something is wrong with my tires...
Edit: I just went outside and tested again, during the day it doesn't happen. Seems like the problem arises when it reaches 47F... which is almost every single night.
And why would I BS this? Only reason people BS (usually) is to make their car sound better, I don't think major slippage is a good thing.
Second Edit: One good thing about it being cold (i was driving 2 days ago in 37F) is the engine is noticeably much more powerful then during the day.
Old Mar 17, 2002 | 02:49 PM
melteye's Avatar
Went outside when it was 57F... Still the same problem. In 3rd and tires slip when going 1/2 - 3/4th from a stop.
Old Mar 17, 2002 | 03:33 PM
see5's Avatar
How can I get mine to do that?
02 6 sp
Old Mar 17, 2002 | 03:57 PM
BioMaxDDS's Avatar
Maybe there is no more "rubbers" on your tire?
Old Mar 17, 2002 | 05:33 PM
zeitgeist57's Avatar
I feel your pain!!!
After a few mods my Max has developed a bad case of tire spinning whenever I pull up next to an A4 or 3-series atty:
Old Mar 17, 2002 | 05:56 PM
Larrio's Avatar
The Definitive AE Master
hey melteye, i live around your area (riverside) but I never experience that type of third gear wheel spin. Maybe it really could be your tires.
Old Mar 18, 2002 | 12:15 AM
melteye's Avatar
My tires are new (I got the car less then a week ago) so I doubt it's the absence of rubber hehe
I am in Riverside alot, maybe sometime I could show you... I don't want to keep these tires if the dealer sold me bad ones.
Old Mar 18, 2002 | 12:20 AM
Larrio's Avatar
the bridgestone potenza's are not great tires, but only in rainy conditions. Are you saying that the tires are spinning at WOT when the auto tranny shifts from 2nd to 3rd? I've been trying to see if that happens with mine, but I can't duplicate it.
Old Mar 18, 2002 | 12:26 AM
melteye's Avatar
I am at a stop sign... The shifter is on 3. I then press the gas 3/4 of the way down and the tires spin and then it takes off. (i actually get some forward movement while it screeches)
Old Mar 18, 2002 | 12:33 AM
ChillWill2000's Avatar
OOOoooo I see I thought you were saying that when your driving around(vehicle in motion) and you hit the gas only 3/4 of the way you get wheel spin... I didnt know you were talking about from a dead stop. Your tires are spinnig because you have a car with an excellent above average engine with plenty of torque on hand. Just learn the period of accelaration right before the tires break lose and youl;l be fine.
Old Mar 18, 2002 | 12:38 AM
melteye's Avatar
I have gotten it down to making the car only make chirping noises hehehe... Push it down until I hear it lose traction then let off enough for it to stop, then when I reach 15 I accelerate harder.
300 miles to go until I reach 1000 Then I can WOT.
Old Mar 18, 2002 | 03:25 AM
Norm Peterson's Avatar
Nothing mysterious here. At a stop the tranny goes back to low gear. Just like what us stick-shift guys do for ourselves. Even while a wheel is spinning it is giving some traction, so you will move forward.
And LSD (limited slip differential) makes one-wheel spin much more difficult. With LSD the side with better grip gets more power instead of much less (with a 1-legger).
Norm
Old Mar 18, 2002 | 07:20 AM
Max_Gator's Avatar
geez - I thought what he was saying was pretty clear.
Old Mar 18, 2002 | 07:27 AM
soundmike's Avatar
Very sound, Mike
Some things i noticed on my Max.
When i first got it, the wheels chirped and spun on almost any type of surface regardless of whether i was at WOT or not.
As the miles started racking up, the wheelspin started going away. I'm assuming that the tires have finally "broken in" as well and thus a bit more grip. Of course, wet road traction is still very tricky even at 2k rpm from a stop.
When i installed the FSTB torque steer also seems to have gone away, it feels like both wheels are more planted on the ground equally. It also helped get rid of some of the wheel spin which causes the steer.
Old Mar 19, 2002 | 12:10 AM
02MaXiMa_GLE's Avatar
Just what I wanted to hear, soundmike! FSB it is
then!!!... now where are those group deals
again... click, click, ahh.. here they are!
G
Old May 25, 2021 | 01:14 PM
Alpha-96's Avatar
1st I'd check your transmission an fluid out,
could be a bad filter in trans also,
Or maybe at night their is dew on the roads from cooler weather, depends on the road also,
some rds in my 06 maxims I can spin my tires all day and some rds I cant get no spin but a rrrt tire chirp lol
Old May 25, 2021 | 02:17 PM
You're replying to a thread that is nearly 20 years old....... Plus, you're in the wrong forum if you have an 06 maxima.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
