How do I know if I have HLSD?
I bought my 2002 Maxima as it was being unloaded from the carrier, so it never had a window sticker. I have been reading about the limited-slip differential, and I honestly have no idea if my car has it or not. Can anybody give tell me how I can find out (besides doing burnouts in the street)?
Re: How do I know if I have HLSD?
Brian
Originally posted by soundmike
Jack the car up so the front wheels hang freely. Turn one wheel, if the other turns the opposite way you have LSD.
Easiest way to tell if you have a VLSD, jack up the front and turn one of the wheels. If the other wheel turns in the same direction OR doesn't turn at all, VLSD. If it turns opposite, it's an open diff. (note, this test will not work w/ the HLSD)
Another method is to floor it from a stop. If you have two black rubber strips of equal lenght you have LSD.
You guys are forgetting, on an even surface, you CAN spin both wheels with an open diff.
Originally posted by Paul D.
Don't bother with the spinning tires test because it wont tell you much. Early production 6 spds spin both tires in virtually all circumstances, actually I've yet to see a situation where only one tire was spinning. I suspect all late production run 6 spds will have HLSD and dealers probably shouldn't be charging for it.
http://forums.maxima.org/showthread.php?threadid=76610
http://forums.maxima.org/showthread.php?threadid=99704
mike, im not trying to say you're wrong. ive just noticed that many people agree with you and say what you just said but then many others say those methods will not work. im just curious to find out the REAL answer.
I am not sure there is a for sure way to find out. I went through this about a month ago.
1.) Called Nissan - talked to a complete boob who didn't have a clue.
2.) Tried to see if there is a code in the VIN - there is not
3.) Did not try the wheel spinning in the air because I don’t believe that accomplishes anything.
4.) Tried to see if there were unique markings on the engine/trans - found nothing.
5.) I have the drilled-metal pedals
6.) My car was built on Dec 21st
7.) Both tires spin around corners and in the rain
If you agree with 5-7 I would bet that you have it. Especially if you got it right off of the truck, the dealer would not have time to install the drilled-metal pedals (meaning it came from the factory like that).
Without opening up the internals of the drive train, I am not sure there is a 100% positive way to find out.
Brian
Brian
No problem dude. Thanks for correcting me. I've edited my post.
Btw, i never said it would test for HLSD, i just mentioned LSD as a general term (which i also use loosely and interchangeably with Differentials in general) so partially i was correct.
Additionally, having HLSD should give you a more even strip on the road... that's based on my experience on the 2k2. I get torque steer before i can even put a decent length of strips down - and i attribute this to the lack of any Traction control system
Sure both wheels spins but not evenly.
by the way, i didnt mean to say you were wrong. you very well could be 100% correct. nothing says the quotes i posted are correct. i was just posting them to show what i was talking about, so many people say one thing while so many others say the opposite.
no biggie really!
i could also be 100% wrong ya know.
btw, here's my theory on LSD's... inspite of the presence of torque steer - the way i understood it, the system will give ample power to both wheels. Given both of them are on the ground at the same time on an even surface that would equate to equal power to both of them and theoretically equal length strips.
i could also be 100% wrong ya know.btw, here's my theory on LSD's... inspite of the presence of torque steer - the way i understood it, the system will give ample power to both wheels. Given both of them are on the ground at the same time on an even surface that would equate to equal power to both of them and theoretically equal length strips.
I don't get it. First I see threads upon threads about people searching 3 different states high and low for HSLD, now there is a page long thread of people who have it and can't even tell. Is there that much of a difference?
Brian
Here's the way to tell.
1) Take a hard 90 degree left turn fairly quickly. Do not brake going into the turn, do not accelerate. The car should understeer/plow going into the turn some.
2) After coming past the apex of the turn lay on the gas hard in 2nd.
3a) If the car continues to plow, or maybe plows worse after a judicious application of the throttle you do not have a HLSD. Sorry better luck next time.
3b) If the car bites and pulls the car hard to left (stopping the understeer/plowing) nearing taking you into a curb then congratulations your car has HSLD.
Stereodude
Originally posted by see5
Mine was a DEC car and came with sticker that did not list LSD yet it showed on the invoice so my dealer ordered the proper sticker with the VIN on it and it shows HLSD.
Stereodude
two people with no sticker?
I'm not saying this happened to you, I'm only commenting on the sticker. It is a felony in the United States for a dealer to sell a new car without a window sticker.
A common (?) scam goes like this...
you: (pointing at car on lot) I want *this* car with HLSD
dealer: I can order/locate it for you
you: OK, order it (you leave)
dealer: (rips sticker off car on the lot and hopes you don't ask) Hey, your car is in!
you: (just bought car and paid for an option you didn't get)
Moral: never buy a car without a sticker. Even "just coming off the truck" it should have a sticker. It should have been on the car *before* the car was put on the truck!
http://www.carbuyingtips.com/scams.htm#Scam10
Originally posted by Stereodude
Mine was made on Christmas day in Japan. It most certainly has HLSD. I ordered it with HLSD and I most certainly got it. The car did not have a window sticker on it when I bought it so I can't vouch for what was on the sticker. Just to clarify not only was the sticker not on the car, I did not get the window sticker.
Stereodude
Stereodude
Re: two people with no sticker?
Not to mention I am 100% certain the car has a HLSD. There are several other driving "tests" (that I didn't mention) that will determine if the car has HLSD. Mine passes all of them.
Stereodude
KabirUTA13
19
Oct 17, 2015 02:15 AM
