Turbo Maxima
Old Apr 7, 2002 | 08:52 PM
MaxPower2K2's Avatar
Turbo Maxima
check it out
http://maximaproducts.com/movies/turbomaxima.mpg
Old Apr 7, 2002 | 09:10 PM
LeftlLane's Avatar
where was this done? I would be interested next summer.
Old Apr 7, 2002 | 09:22 PM
NuJerseyDrive's Avatar
OMG
Someone please make this happen!
Old Apr 7, 2002 | 09:44 PM
rerunn's Avatar
That was a 4th gen max wasnt it??
Old Apr 7, 2002 | 10:30 PM
KLOOGY's Avatar
L33t BMW Drivah
I'd love to shoot that video out of my 2K2 with a Turbo in it !
Old Apr 7, 2002 | 10:33 PM
20th maxstyle's Avatar
how bout an AE with twins. Gimme until June 29th. Chicago HIN
Old Apr 7, 2002 | 10:36 PM
MyownNismo's Avatar
Future Camaro SS owner
Could I use a turbo with an automagic. I would be interseted if it could happen.
Old Apr 7, 2002 | 10:42 PM
mine is auto.
Old Apr 7, 2002 | 10:43 PM
FastCougar's Avatar
That car's engine is hurting or that camcorder needs a new mic ... that did not sound good at all when the hood was up. That metal on metal whine can't be good ... bad bearing, loose rings, bad turbo ball bearing (if equiped), etc. ... you pick. Regardless of the choise, it can't be very good. Hopefully this guy was smart enough to lower the compression to run moderate boost (6-12psi) or is smart enough to know that if he didn't, he shouldn't exceed 6 psi.
Old Apr 7, 2002 | 11:04 PM
MyownNismo's Avatar
mine is auto.
And your getting twin turbos I got to see this and would want this, not twins just maybe a T4 turbo. What are you going to need to do for the tranny to hold all that.
Old Apr 7, 2002 | 11:06 PM
Thank the lord for level 10
Old Apr 7, 2002 | 11:19 PM
MyownNismo's Avatar
That's it.
Old Apr 7, 2002 | 11:30 PM
BigDogJonx's Avatar
This guy is NUTTS to be trying a run while there is still snow on the roads and the side............ Damn..........
Turbo does seem nice. If he can do it, then Ill be damned it can be done in a 5th gen.
Dixit
Old Apr 7, 2002 | 11:34 PM
manifold will be done by an aeronautics company that wants in on the import scene.
Old Apr 7, 2002 | 11:49 PM
K Pazzo 6's Avatar
That would be kick a$$...what does 'HIN' stand for?
Old Apr 7, 2002 | 11:51 PM
Hot Import Nights.
Old Apr 7, 2002 | 11:54 PM
KLOOGY's Avatar
L33t BMW Drivah
Sign me up for the " TWINS "...
Old Apr 7, 2002 | 11:57 PM
K Pazzo 6's Avatar
Hot Import Nights.
Straight I'll probably come down to check out your ride since I'm from the chicagoland area....are you also going to be attending the import show @ the Odeum that APG Performance is sponsering on 05/25?
Old Apr 8, 2002 | 12:23 AM
MyownNismo's Avatar
How much it costing.
Old Apr 8, 2002 | 05:54 PM
ill take 4 to go please, haha
twin turbo
hmmm
Old Apr 8, 2002 | 06:03 PM
Greg's2kGLE's Avatar
I think he had four or five people in the car.
Old Apr 8, 2002 | 06:26 PM
Newman's Avatar
i am very seriously getting a turbo on my car this summer. i only have so much money so im wondering if i should get a body kit and forego the turbo or get the turbo done sometime this summer. i think im going to go with the turbo. 90% chance that this will be done.
Old Apr 8, 2002 | 06:47 PM
GET THE TURBO!!!!
Old Apr 8, 2002 | 06:57 PM
2001SE's Avatar
there are already turbocharged 4th gen maximas. don't get too excited lol , it must be done custom and it will cost a LOT!
Old Apr 9, 2002 | 12:50 AM
MyownNismo's Avatar
20th maxstyle I want your front bumper it's the same color as mine I thought it would've liked bad but it looks bad***. Can't wait till you get the grill in place. How much did it all cost.
Old Apr 9, 2002 | 03:55 PM
Tanman's Avatar
Modifications
I don't see the battery in the engine bay. Did you have to move it to the trunk or somewhere else? Did you have to move anything else?
For whoever suggested using a T4, I doubt it would fit correctly. Am I right or wrong?
Old Apr 9, 2002 | 04:04 PM
20 MAXIMA 02's Avatar
Re: Modifications
hey guys, flame away at my ideas ...
twin turboing the 2k2 maxima seems possible if you turn the engine around 90 degrees and install the stillen short ram intake.. This then provides 2 things
the stillen intake will be sucking air directly from the gap in the hood
and the engine will be mounted in a way that negates the use of a y pipe so dual catalytic converters with equal length headers is possible...
then this just leaves the small problem of where to mount the turbos... but you will have the engine alligned for twin turboing.
Old Apr 9, 2002 | 04:19 PM
Re: Re: Modifications
Ummm, you can't turn the engine. If you turned it 90 degrees, it would be configured for RWD. So I don't know what you are talking about.
Old Apr 9, 2002 | 04:31 PM
Re: Re: Re: Modifications
how do u mean configured for rwd? ... i figure that honda accord v6 engines have the cylinder banks facing each wheel well, whereas nissan mounts the 3.5 liter transversally on the maxima.
Old Apr 10, 2002 | 06:47 AM
Jer's Avatar
Jer
Ew. Those guys are HORRIBLE for quality control. And some members of another club have had customer service issues with them... stay away!
Old Apr 10, 2002 | 06:59 AM
Jer, I've had my L10 tranny stage 3 for 5 months, and no problems here
As for TT set up, its not all that easy, but it can be done. Two T3/T4s could be set up. Can always have a T25 spool from the rear bank, Hobbs switch allowing T3/T4 or T04(If so inclined) to flow.
Get great response low end and high end.
In the end, who cares ?
Old Apr 10, 2002 | 07:28 AM
jjs's Avatar
jjs
Re: Re: Re: Re: Modifications
Uh, take another look at a Honda....
http://www.sounddomain.com/member_pa...=149382&page=3
Old Apr 10, 2002 | 08:17 AM
Re: Re: Re: Re: Re: Modifications
Acura Legends 91-96 had engines that were longitudily installed(RWD) but were FWD.
Old Apr 10, 2002 | 08:20 AM
jjs's Avatar
jjs
Re: Re: Re: Re: Re: Re: Modifications
Nice to know, but he did say Accord...
Old Apr 10, 2002 | 08:32 AM
Stereodude's Avatar
I suspect people will do a fair bit of flaming. Unless you are doing a RWD conversion I don't see how this is going to happen. Very few cars have a longitudinally mounted engine that are FWD. You're talking about a custom tranny and the works.
Stereodude
Old Apr 10, 2002 | 10:37 AM
SillePimp's Avatar
Re: Turbo Maxima
Originally posted by MaxPower2K2
check it out
This has been in the 4th Gen forum for some time now. This guy recently had the turbo tuned near 9 psi and is putting 340+ hp and torque at the wheels. Don't know the exact numbers.
Old Apr 10, 2002 | 06:18 PM
ah **** your right ... i hate being wrong ... learn sumthing new everyday
Old Apr 10, 2002 | 06:47 PM
turbo97SE's Avatar
That's actually my car in the movie! You can see the dyno results in the 4th gen forum. It dynoed at 352 HP and 549 ft-lbs at the wheels at 9.3 psi. The results were not very accurate because of my slipping clutch.
The results are here:
http://forums.maxima.org/showthread....5&pagenumber=2
I am wondering if this will fit a 5th gen. Anyone know the differences in the enginebay area between 4th and 5th gen?
Interesting that the video made it on to Maximaproduct.com without my knowledge.
Nigel
Old Apr 10, 2002 | 06:50 PM
turbo97SE's Avatar
That's actually my car in the movie! You can see the dyno results in the 4th gen forum. It dynoed at 352 HP and 349 ft-lbs at the wheels at 9.3 psi. The results were not very accurate because of my slipping clutch.
Nigel
Old Apr 10, 2002 | 10:21 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Nigel
I'm 90% sure it'll fit.
