CD player question
Old Apr 23, 2002 | 04:53 PM
JJL's Avatar
JJL
CD player question
Can the Cd player in the max play back CD writes
I tried to make one using easy CD creator 5 on my PC
It would not play back the music in the maxima
Thanks for any help and any tips
Old Apr 23, 2002 | 04:56 PM
lcf's Avatar
lcf
the bose system in my max plays cd-r's fine.
what brand of cd-r you using?
some suck.
Old Apr 23, 2002 | 05:24 PM
see5's Avatar
Works for me.
Old Apr 23, 2002 | 05:51 PM
JJL's Avatar
JJL
some suck.
TDK with a plextor burner
I am kind of new makeing music CD's
I use my cd burner mostly to make data cd's
The one I made works on my pc but not in my maxima. Maybe I am doing something wrong is there any special way to make a music cd.
thanks for help
Old Apr 23, 2002 | 06:59 PM
suds1's Avatar
All CD players kinda have a mind of their own. I have burned CD's that work in the max and will not work in my home stereo and vice versa. One thing I have found that helps is to burn them at a slower speed (If your CD burner has that option) and always use good quality CD-R's. They make CD-R's specifically for music that are supposed to work better for this application.
Hope this helps.
Old Apr 23, 2002 | 07:27 PM
azhelipilot's Avatar
Also sometimes on some you have to close out the CD after burning them --- unstead of leaving the CD open to put on more music.
Old Apr 23, 2002 | 07:38 PM
Green_2's Avatar
thanks for help
Don't take this the wrong way, but maybe you made it as a data CD?
For me, I always use the options: disk at once and close CD. Disk at once is particularly useful when you don't want the anoying pause between dance mix tracks.
Old Apr 23, 2002 | 09:22 PM
dragon02se's Avatar
Re: CD player question
assuming that all other burning is done correctly, you might want to burn the cd at a lower speed. sometimes, high burn speeds are difficult to read for certain players. also, try using NERO instead of CD Creator.
Old Apr 24, 2002 | 01:21 PM
JJL's Avatar
JJL
Re: Re: CD player question
Thanks for all your help people . I made some adjustments and now have it working fine
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
