Possible Electrical Short.....Need Help
Old Apr 23, 2002 | 06:52 PM
blackmax2000's Avatar
Guys I have a problem, I recently purchased a set of polarg bulbs for the front and rear turn signals, I installed the rears and didn't have a problem. I installed the fronts and was driving out the driveway when all the turns went out, sidemarkers went out, instrument cluster went out too. Whenever I activate the turns both sides blink as well as sidemarkers and instrument cluster. What could have happened?
Old Apr 23, 2002 | 07:33 PM
BigDogJonx's Avatar
Re: Possible Electrical Short.....Need Help
If you did the side marker rewiring, you messed up the wiring.
Dixit
Old Apr 23, 2002 | 07:34 PM
Green_2's Avatar
Check and see if any of the fuses got zapped.
Otherwise, check the wire connections where you spliced in to make your sides blink, maybe they came loose.
Old Apr 23, 2002 | 07:40 PM
Tanman's Avatar
Same thing happened to me. Fuse snapped. In the engine bay off to the right. Look at the top of the cap for the "acc light" fuse or something like that. Replace it with one of the spares from under the dash of the same rating.
Old Apr 23, 2002 | 09:16 PM
thanks guys, but i haven't rewired them, they blinked on their own
Will replacing the fuse solve the problem or will it blow again?
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
